  • Guests: 41
williamn (48)
ReddyK (57)
Birdman (31)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
Printing Circuit Boards
Chip Fixes
Thu Sept 01 2011, 08:21PM
Chip Fixes Registered Member #3781 Joined: Sat Mar 26 2011, 02:25AM
Grenadier wrote ...
How about printing directly on copper clad, followed by a standard etch?
That sounds good, but how do you get the copper clad through the printer?
Adam Munich
Thu Sept 01 2011, 09:45PM
Modify it somehow. shouldn't be that hard
Chip Fixes
Thu Sept 01 2011, 10:07PM
I have 5 printers lying around, maybe i'll do some experimentation. Any suggestions on what to try first?
Adam Munich
Thu Sept 01 2011, 10:36PM
PCBs aren't flexible, so you'll probably have to cut a hole in the back of the printer for it to fit in there. You also might need to separate the rollers a bit.
Thu Sept 01 2011, 11:07PM
Does anyone know if the typical toner youlll be using is water resistant? HCL or FC are both aqueous.
--Will the deposited toner be thick enough to be useful?
--Is it possible to use a laser printer with melted toner powder?
Tue Sept 06 2011, 11:10PM
You can't use a laser printer, since the copper clad is conductive wink
It shouldn't be that bad to modify an inkjet to do the job, although getting a thick enough layer of ink to survive the etch process might be tricky. And all inkjet ink is very water not soluble, at least after it has dried--just ask anyone who has had to deal with a leaky ink cartridge!
Tue Sept 06 2011, 11:46PM
Hi Peter,
Why would conductivity be a problem here? Not from what I know of laser printers, as it's the green roller that gets point-charged and then deposits the toner to paper, or pcb.
