  • Guests: 49
Lyonel Baum (77)
Mattc1886 (17)
01/09 RickR (18)
01/09 TheBoozer (58)
01/09 invader (50)
Theory Help!
Electrix
Sat Aug 20 2011, 04:56PM Print
Electrix Registered Member #4060 Joined: Sat Aug 20 2011, 04:53PM
I am making a Toroid out of Galvenized 3" Ducting. I have several design questions:
1. Can i fill the inside with foam insulation filler to prevent it from denting inwards? And if I do would it change the capacitance?
2. Can I spray the outer edge with a high temperature resistant spray paint even if its not conductive? Or would that effect it?
Thank you!
Would this work? Link2
so if i attached the secondary JUST to the metalic paint would the outer coating act as the breakout?
Or what about tinfoil ... and if i put a high temperature Clear coat over the outer surface would it play a role too?
MODERATOR: double posts removed.
Sat Aug 20 2011, 05:04PM
1) As I understand it, it is only the outer surface of your topload that adds to the capacitance.
2) In regards to the answer above, I am not sure if this is a problem, if you had a breakout point.
