  • Guests: 50
Improving a Jacob's Ladder
radioman
Sat Aug 20 2011, 01:11PM Print
radioman Registered Member #3026 Joined: Fri Jul 23 2010, 02:46PM
Hi everyone,
Is it possible to but a voltage-appropriate MMC across the output of my NST used in a Jacobs Ladder? Wouldn't this really make the arc more dramatic?
Thanks!
cduma
Sat Aug 20 2011, 03:34PM
I think it would make it far too loud. The only point to adding an MMC would be to make it resonant.
Forty
Sat Aug 20 2011, 05:38PM
i've always wanted to see one made as a spiral.
if you want dramatic, make the ladder into a plasma speaker that plays epic music as the arc travels lol.
mikeselectricstuff
Sat Aug 20 2011, 11:19PM
A small amount of capacitance (100s of pf) on a JL can make it considerably louder and more crackly due to the increased current when the arc strikes on each half-cycle, but you need to be careful to avoid it being high enough to resonate with the secondary as this may cause the transformer insulation to break down
Sun Aug 21 2011, 12:30PM
Or choose a capacitance to deliberately resonate with the secondary (well, more likely a "LTR" capacitor) to make the arcs hotter and much longer.
Tetris
Sun Aug 21 2011, 07:26PM
But don't you like the 60hz hum of it? capacitors ruin the wonderful 60Hz hum! or 50 if you live elsewhere
cduma
Mon Aug 22 2011, 02:26PM
No, they do not. Its still 120Hz but, more than a hum.
Mon Aug 22 2011, 03:54PM
Series capacitors just make the arcs sound more "angry", the sound has louder harmonics if you want to be technical. But it still hums at the mains frequency.
magnet18
Wed Aug 24 2011, 02:05AM
Forty wrote ...
Done and done-
Forty
Wed Aug 24 2011, 03:28AM
now the arc just needs to sing "the final countdown"
