  • Guests: 63
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
Probes for Tektronix T935 35MHz 2 channel oscilloscope.
Chip Fixes
Fri Aug 19 2011, 05:19AM Print
I recently bought this scope off of ebay and it doesn't come with probes. So I was wondering what kind of probes I should buy? I am a bit confused on what probes are compatible with the scope and what it means by 1x and 10x.
Fri Aug 19 2011, 11:13AM
1x would mean the oscilliscope would recieve the same volts coming into the probe
10x would mean that the ocilliscope it reciving 1 volt for every 10v put into it
im not that sure though
i think ocilliscopes use BNC connectors so any scope probe with a BNC connector should be fine.
although im no leading expert
Ash Small
Fri Aug 19 2011, 11:28AM
I can confirm that what Tom says is correct.
I'd like to add, however, that probes have a 'frequency response'.
I bought two probes after getting my 'scope from Ebay, one for £4.95, that is good to 20kHz, a nd one for £19.95 that is X1 and X10, and good for 100kHz or higher, if I remember correctly.
Chip Fixes
Fri Aug 19 2011, 06:27PM
oh ok, thanks! Are there any connection types that you would recommend? I am on ebay and they rang from a lead with two aligator clips on the end, to a lead with just a probe on the end.
EDIT: These look pretty good: Link2
Sat Aug 20 2011, 09:45AM
yes they do look good, when i have the money and a means to get it onto the web i might even snatch up a pair :D
Ash Small
Sat Aug 20 2011, 10:52AM
Does it say the range is 6MHz to 100MHz?
Does this mean they won't work below 6MHz?
Other than that they look fine.
Bjørn
Sat Aug 20 2011, 11:05AM
The bandwidth of a normal probe depends on the divider setting. If you look at fast signals, always use the 10x setting.
Ash Small
Sat Aug 20 2011, 11:20AM
Bjørn wrote ...
So on X1 it is good for 6MHz, and on X10 it is good for 100MHz?
