  • Guests: 55
Will these IGBs be good enough?
currentkills91
Thu Aug 18 2011, 01:35AM Print
I'm making a small DRSSTC and I was browsing through IGBTs and I came across these -
APT65GP60L2DQ2G
These seem to be better, but I'm not sure if they're fast enough -
APT102GA60L
My question is, is the second one fast enough, if not, will the first one work?
They will be ran at around 80kHz, and i'll be pushing about 300-400 amps...
Goodchild
Thu Aug 18 2011, 07:20AM
Both should switch at 80Khz with no problem. Look at the rise and fall times in the data sheet next time, that is all the info you need to know for switching.
serge petiot
Thu Aug 18 2011, 09:15AM
serge petiot Registered Member #4054 Joined: Sun Aug 14 2011, 01:39PM
Currentkills91,
they've got about the same delay; rise and fall time as the APT50GP60 I was enquiring about, which is given for 200Khz operation. About the same price as these on digikey too! What frequency are you planning on operating?
Tell us how these fare, it's about time, we had more IGBT references on HvWiki for DRSSTC use...
Serge
