  • Guests: 66
High wattage variable resistor
Ash Small
Tue Aug 16 2011, 07:41PM Print
I knocked this up this afternoon, using the heater element from a fan heater.
It is adjustable from 2Ω to 110Ω, just by re-arranging the tapped connections.
It was good for 1kW in the original application, so shouldn't have any problem running at 100 watts or more.
I'm using it as a variable current limiting resistor while running some tests on my 2N3055 circuit, but I'm sure I'll find plenty of other uses for it too.
1313523686 3414 FT0 2 Ohms
1313523686 3414 FT0 110 Ohms
Tue Aug 16 2011, 09:11PM
Homemade resistors are highly useful, but the problem with these is that once they start getting hot, the resistance may change drastically. However it is surely just a nichrome wire, which is what normal resistors are. I think 100w may be fine and the resistance won't vary too much, though. If it does, just blow a fan over the elements, or even soak it in some deionized water or oil.
Tue Aug 16 2011, 09:46PM
I used to use Hair dryers for this purpose, Though they did change resistance as they got to a final temp, then flattened out, often for precision i'd measure the V and I simultaneously since the Absolute resistance value usually doesnt matter much.
Forty
Tue Aug 16 2011, 11:05PM
looks like it will double as a variable inductor at the same time.
Ash Small
Wed Aug 17 2011, 12:00AM
Forty wrote ...
I was thinking that myself. It is air cored, so at low frequencies I'm hoping that won't be too much of a problem.
(EDIT: I might run some tests against light bulbs to see if the inductance has any effect)
Putting it under oil for cooling sounds viable too.
I'll report on progress.
Wed Aug 17 2011, 07:33AM
Ash Small wrote ...
Forty wrote ...
It could double up as a chip fryer.
Forty
Wed Aug 17 2011, 04:09PM
lol. Ash Small's 3-in-1 wonder appliance!
"hungry? need an inductor? sick of fiddling with different resistors? then look no further..."
"feed, impede, succeed!"
Ash Small
Wed Aug 17 2011, 06:35PM
Forty wrote ...
."hungry? need an inductor? sick of fiddling with different resistors? then look no further..."
There is a reason why this thread is in 'general chatting'. It's not to be taken too seriously, but it didn't cost anything and it 'seems' to have plenty of uses, not least as a current limiter.
I do appreciate the humour, though.
Wed Aug 17 2011, 06:52PM
Ash Small wrote ...
Forty wrote ...
There is a reason why this thread is in 'general chatting'. It's not to be taken too seriously, but it didn't cost anything and it 'seems' to have plenty of uses, lot least as a current limiter.
The silliness is all down to me, Ash. It's just that when I came to respond to your post, I was also thinking about going down to the quay and buying a piece of plaice to make fish-and-chips with, and the two things somehow became confounded in my mind.
Forty
Wed Aug 17 2011, 07:08PM
oh I didn't mean to make it sound like it's a bad idea. I'm sure it will make a great variable resistor at low power levels.
