  • Guests: 40
Sanchez (36)
Knarvel (13)
10/17 Madgyver (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Glued transformer core seperation techniques?
Mon Aug 15 2011, 06:56AM
I have tried boiling in mineral spirits (almost a light oil?) to little success. The heat gun method works if done correctly. However, it will make the cores extremely brittle.
haxor5354
Mon Aug 15 2011, 04:58PM
I just tried the boiling water method and it works!!
I boiled it for 20 mins then cool it back down with cold water and I could easily pull it apart
dude_500
Mon Aug 15 2011, 11:30PM
dude_500 Registered Member #2288 Joined: Wed Aug 12 2009, 10:42PM
I found careful temperature control and patience with a heat gun can get them apart after about 10 minutes at a low temperature (don't remember the number, but way below 400C). I just set the heat gun about a foot away and did some other work, and when I went back to pick it up the cores were apart. Although, I have a small sample size - did it once, and it worked, so maybe I got lucky.
Tue Aug 16 2011, 12:00AM
Are yoy guys undoing lacqure? or epoxy?
Mine have black epoxy holding the together!
