  • Guests: 72
Tesla Coil On A Hat
dude_500
Sat Aug 13 2011, 09:11PM Print
dude_500 Registered Member #2288 Joined: Wed Aug 12 2009, 10:42PM
So I've been working on a small DRSSTC coil (about 6" tall) and thought it would be cool to put it on a hat with a battery pack in a backpack. The thing is, I'm not sure about grounding... I was thinking I'd have a metal plate on top of the hat, with the primary and coil on top of that so as to avoid any "head strikes". But, the whole thing will be floating. There's no way to be sure a charge will establish on the top of the coil with respect to ground/me, versus on the bottom of the coil. Is there any good way to make me not continually get shocked by the battery pack and wire discharging to my ground reference, or is this just an all around terrible idea (well, I already knew it was, but is it even hopefully possible?)
Sat Aug 13 2011, 10:05PM
Dude,
I think if you use a tin foil hat, you will be allright wink
Cheers, Finn Hammer
Chip Fixes
Sat Aug 13 2011, 10:27PM
Or you could run a wire or two down to your shoe (hide it under your shirt, etc.)
magnet18
Tue Aug 16 2011, 02:26AM
As far as ideas go, that has got to be the best terrible idea ever
Maybe practicing on a manikin?
Nah
Tue Aug 16 2011, 02:46AM
Nah Registered Member #3567 Joined: Mon Jan 03 2011, 10:49PM
How about a bipolar tesla coil? no need for ground
dude_500
Tue Aug 16 2011, 05:00AM
Nah wrote ...
I was thinking about this, but I think there still kind of is a need for a ground in this case. The whole system would still be floating, what is to say that the driver and battery pack will stay at my human potential, instead of floating to some high voltage then discharging to me? As far as I'm picturing it, I have to be connected to the battery's negative, and if I don't want to get shocked touching anything, I also have to be close to ground potential.
I like the metal-bottomed shoes and will probably give that a try.
Forty
Tue Aug 16 2011, 05:12AM
conductive ink + fabric might be easier than running wires from head to foot.
Ash Small
Tue Aug 16 2011, 11:44AM
Forty wrote ...
Tin foil underwear?
Dr. Drone
Tue Aug 16 2011, 04:09PM
shades
Staci
Tue Aug 23 2011, 04:25PM
Staci Registered Member #1741 Joined: Sat Oct 04 2008, 02:45AM
I made my little wearable one for Jeff Mach's Kinky Geeky event...works fine with no grounding... You got it - just create a virtual ground plate underneath everything and you'll be fine. I don't recommend touching it while it's on...unless that's what you're into. I made a video...see below:
