  • Guests: 61
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Steve Wards DRSSTC UD
currentkills91
Sat Aug 13 2011, 05:00AM Print
Hey everyone, am I able to use something else besides the optical receiver for the interrupter? I ask cause I have no way of using the optical receiver for the interrupter, as I don't have an optical transmitter...
Sat Aug 13 2011, 11:58AM
Optical transmitters are just LEDs...
But remember that investing in some opto's might prove to be a good idea, it provides perfect isolation between your Tesla coil and whatever interrupter, midi board, computer etc. you have in the other end.
Tetris
Sat Aug 13 2011, 06:46PM
I wish I could build a DRSSTC... All I can build is a SGTC, and even that, it's an issue of getting it to work, and getting capacitors. But I will not give up! People had said that they took 3 years to build their first coil! So I WILL! I WILL get it to work! And I will be able to build a DRSSTC in a few years! Well, at least a SSTC... but good luck with your interrupter. Hopefully you won't need three years to build your coil, or hopefully money isn't an issue.
Goodchild
Sat Aug 13 2011, 07:32PM
The optical TX and RX units are very easy to get and are not all that expensive. I would go as far to say that it's almost required that you use them for a DRSSTC. If you don't you will most likely have noise issues.
TX unit - OPF1412T
RX unit - OPF2412T
you can buy both here:
TX - Link2
RX - Link2
dude_500
Sat Aug 13 2011, 08:53PM
dude_500 Registered Member #2288 Joined: Wed Aug 12 2009, 10:42PM
The IF-E96 (Transmitter) and IF-D95OC (Receiver) also work well, and cost much less (Digikey FB128-ND and FB124-ND). They are TTL out , and don't require connectors on the fiber which is convenient.
Sat Aug 13 2011, 11:26PM
dude_500 wrote ...
I also use these and recommend them, just be aware of different polarity of some opto receivers when compared to f.ex. Steve Ward schematics.
currentkills91
Mon Aug 15 2011, 01:47AM
Thanks for the replies everyone, i'll go ahead and get the optical Tx and Rx units (:
teravolt
Mon Aug 15 2011, 02:10AM
plastic fiber optics also work and are cheaper. like the hfbr-15xx and hfbr-25xx series. a good place to get them is jameco electronics
Mon Aug 15 2011, 06:29AM
Mads Barnkob wrote ...
dude_500 wrote ...
I have been using these types for 6 years without anything but success, on DRSSTC, SISG and T_BRISG and VDG.
I usually use the IF-D95T, which is TTL out.
The IF-D95OC, however, has an open collector output and can therefore be pulled either up or down.
Cheers, Finn Hammer
