  • Guests: 35
01/13 si2030 (62)
putting an end to leukemia
hboy007
Fri Aug 12 2011, 09:39AM Print
"Genetically Modified 'Serial Killer' T-Cells Obliterate Tumors in Leukemia Patients
ScienceDaily (Aug. 11, 2011) — In a cancer treatment breakthrough 20 years in the making, researchers from the University of Pennsylvania's Abramson Cancer Center and Perelman School of Medicine have shown sustained remissions of up to a year among a small group of advanced chronic lymphocytic leukemia (CLL) patients treated with genetically engineered versions of their own T cells. The protocol, which involves removing patients' cells and modifying them in Penn's vaccine production facility, then infusing the new cells back into the patient's body following chemotherapy, provides a tumor-attack roadmap for the treatment of other cancers including those of the lung and ovaries and myeloma and melanoma."
______________
Just thought I'd share my excitement with you. Maybe a few have run across this article Link2 one year ago. The lentvirus import of genome sequences seems to be a hot topic in cancer research. However, at least when induced stem cells are used, the procedure had turned out to create more problems than it fixes since the forced changes in the cells cause uncontrolled mutations. As far as I can tell, the approach taken above directly targets T-cells in a controlled environment and permits testing the stuff in vitro. Maybe they let some of the t-cells multiply, sequence their genome to check for mutations and finally apply the T-cells to the patient.
Fri Aug 12 2011, 01:54PM
hboy007 wrote ...
______________
I saw all this on TV and was stuned at how effective it has been all ready, another 20 years and this could be the next treatment for cancer that isnt barbaric.
