  • Guests: 42
Sanchez (36)
Knarvel (13)
10/17 Madgyver (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Problems measuring an inductor
Avi
Thu Aug 11 2011, 03:59AM
Good work with the helix. Do you know what was wrong the first time?
No, I'm not sure, but its only the 2nd time I have tried the parallel resonance method.
As for the spiral coil, you didn't say it was a foil coil. I had interpreted the 2.5-mm primary thickness as an axial dimension (i.e. wire diameter) instead of the radial thickness of 11 turns. Is the 2.5-mm a measured value, so thickness per layer is about 1/11 of that?
2.5mm/11
Self-capacitance could be a significant contributor here. Have you done the frequency-swept amplitude measurement with no added capacitor?
no but i would imagine it to be a function of impedance 3s the onboard 300 ohm
dimensions:
coil inner diameter: 16 cm
coil thickness: 2.5 mm
coil turns: 11
coil wire thickness: 0.227 mm
coil wire height: 7cm
