  • Guests: 45
3.8KW 40A 220V Power Adjustable Thyristo
Juniortore1
Sat Aug 06 2011, 11:41PM Print
Juniortore1 Registered Member #4014 Joined: Wed Jul 20 2011, 05:31PM
I saw this on ebay Link2
It seems like a simple solution to an expensive variac. I have a few questions though. Would the output still be 50/60Hz? This would be cool to mess around with my ZVS using a power transformer as a ballast. Any ideas? Thanks
Sun Aug 07 2011, 05:42AM
That is basically a light dimmer, and while it will work great for resistive loads (lightbubs, heaters) I suspect that if you try to drive a transformer from it it won't last very long.
it is possible to drive transformers using a triac like that, but you need to add an additional snubber network to keep from killing the triac.
He does say it works for motors, so I suppose it is worth a try...
Dr. ISOTOP
Sun Aug 07 2011, 07:06AM
Definitely worth a try, seeing as its only $10...I doubt its very robust, and I highly doubt it can drive an inductive load at 3.8KW (the 40A is probably the absolute limit of the thyristor it uses).
Juniortore1
Sun Aug 07 2011, 06:27PM
Okay, when some money, I will buy one and make a review on it. I figure 20A to be more of a suitable max. If it is a triac, it cannot power a normal 60HZ transformer as I tried it with a light dimmer. Although, I did not use a capacitor in series with the transformer and triac, I should.
Inducktion
Sun Aug 07 2011, 09:08PM
Could you use a light dimmer circuit as a DC power supply? Since the SCR cuts off certain parts of the wave, then you could vary the voltage accordingly, and then smooth it out with a capacitor giving a nice variable DC power supply.
Mon Aug 08 2011, 01:06AM
I have seen these used for inductive loads such as MOTs and they seem to work just fine. I wouldn't try to use them at their max rated current with an inductive load though, it might work but then it might not.
Mon Aug 08 2011, 06:45AM
A much more stable approach to this is getting a Variable Frequency Drive and connect a 3 phased transformer instead of a motor, it will also need some capacitors to insure proper operation.
The transformer will make strange and often mechanical stress sounds, but it works like a charm for generating all the voltages you want. At a former workplace we had one that could give 3 phased 200-230-380-400-440-480-690 Volts from a 3x400 Volt input.
A VFD is built for inductive loads in difference to the dimmer circuits, a VFD is also a great build quality and have many protective circuits to insure a long life.
Gettting a used 1kW VFD should be no significant expense unless you want one right away, find the right places to look and they come cheap :)
Adam Munich
Tue Aug 09 2011, 03:08AM
Inducktion wrote ...
Hrm... that's an idea. DC variac, unregulated but meh.
I shall try it.
Inducktion
Tue Aug 09 2011, 04:11AM
Oh, and of course, you would need to rectify the output, but yes.
Mattski
Tue Aug 09 2011, 04:36AM
I'd suggest putting a certain amount of inductance in series with that capacitor otherwise you could get a fairly large current spike when the thyristor turns on.
