  • Guests: 53
Another power scam...
LD LANGER
Wed Aug 03 2011, 03:14PM Print
LD LANGER Registered Member #3824 Joined: Sun Apr 10 2011, 08:29PM
These guys are pretty lazy. Buy a capacitor, claim it as perfect pfc, sell it for $350. How does this still happen?
Main claim is that the power factor of your household loads are very low and this thing will decrease power consumption by up to 40%.
Can someone just DDOS this site please.
Mattski
Wed Aug 03 2011, 04:42PM
Improving power factor can increase efficiency. But for residential loads consumers are typically only billed for real power delivered, not reactive power, so PFC will not do anything for the actual bill.
Plus every page on their website sounds like a scam rife with unsubstantiated claims.
Adam Munich
Wed Aug 03 2011, 06:53PM
It's a new 'trend'...
LD LANGER
Wed Aug 03 2011, 07:16PM
That one is even worse! Read the description on how it works, I can't believe people fall for this garbage.
haxor5354
Wed Aug 03 2011, 07:44PM
website looks like it was made by a kid
haxor5354
Wed Aug 03 2011, 07:51PM
Grenadier wrote ...
electromagnetic amps!!!! ahahhaaaa that just made my day
radiotech
Wed Aug 03 2011, 08:30PM
The power savers do, in fact work. I tested a couple when they came out
years ago, marketed as "green plug"
But they only make sense where electricty is very costly i.e. communities
served exclusively by diesel electric plants.
They work on motor loads by electronically bringing the power factor to close to
100%. Back then a washing machine or fridge an effeciency of at best 70%
with the induction motor. This translated into a PF of about 80 %. By bringing the
PF to 100 %, line amps dropped, and voltage to the appliance increased reducing
motor amps and reducing heat loss. An induction motor, at a constant horsepower
output, draws more current at lower than rated terminal voltage.
The heat loss in all the wiring from the load side of the utility meter to the appliance
is paid by the customer.
They were supported by our Provincial utility, and the gadget paid back the $40. odd
price in about 5 years if I recall. When this new computer is working well. I'll post the
docs and perhaps a photo of the thing.
Trying to use a capacitor in a home application can lead to unexpected trouble. You
dont want vars running around you home wiring, especially with the modern SMPS
loads.
Inducktion
Thu Aug 04 2011, 03:31PM
I actually saw a commercial for this thing on TV. Poor people.
Daniel Kramnik
Sun Sept 04 2011, 03:29AM
Daniel Kramnik Registered Member #3885 Joined: Sun May 15 2011, 12:47AM
The website in the original post fails to load and the commercial for the "Ampilizer" contains "special" effects that literally use the stock, preloaded emitters from Particle Illusion. How does this kind of thing even exist!?
testtest
Sun Sept 04 2011, 07:54PM
testtest Registered Member #3271 Joined: Mon Oct 04 2010, 02:29AM
LD LANGER wrote ...
Link looks down. Interesting comment here:
Wonder if this is the same unit:
Ha: found them back on the internet archive site:
$350 is steep for a capacitor in a box. Can see the reason with large inductive loads in industry but but modern home motors are better designed now. Also what would be the effect on the rest of the house in the event of a spike or transient? In particular with all the electronics floating around these days....
Here is another one:
