  • Guests: 40
Wire size for mini SSTC
currentkills91
Tue Aug 02 2011, 09:00PM Print
Would 40 gauge wire work for a mini SSTC? I wanna make a tiny SSTC but 40 gauge wire is all I have. The secondary would be about 1.5 inches in diameter and I would wind around 1200 turns. Think it would work?
Dr. ISOTOP
Tue Aug 02 2011, 09:29PM
Go calculate the f0 and see whether your switches can switch quickly enough...
currentkills91
Tue Aug 02 2011, 09:34PM
The frequency of the secondary would be just under 600 kHz with topload, and my FETS can switch as fast as something like 3 MHz. I mainly wanna know if the wire is gonna be able to hold up in this application?
Wed Aug 03 2011, 08:24AM
My SSTC III, that you can see here: Link2 is made with AWG38 and it was a real pain to make that secondary, on/off about 6 days.
In the end it will work fine for small systems and you will often love the tiny little coil with a low frequency that you get from it :)
Its frustrating when the wire breaks!
Dr. ISOTOP
Wed Aug 03 2011, 09:03PM
currentkills91 wrote ...
What power FETs are you using that can switch at 3MHz? Or is this Class-E?
currentkills91
Wed Aug 03 2011, 10:27PM
I planned on using IRFP260 FETS, so more like 2 MHz if you do it right?
Dr. ISOTOP
Wed Aug 03 2011, 11:38PM
Your MOSFETS will not be very happy running at 2 MHz unless you do Class-E.
At 600 KHz, they'll be OK at low current.
currentkills91
Thu Aug 04 2011, 03:21AM
Yeah, the actual frequency is lower now as I got more turns than I expected. The resonant frequency without topload is a little over 800 kHz, so I'm guessing something like 500 kHz or so with topload. I wanted to do a Class-E coil, but I'm not sure that tuning would be all too easy with the equipment I have...
