  • Guests: 56
Soldering stereo microscope
rp181
Thu Jul 28 2011, 01:23AM Print
I have been soldering .5mm pitch chips and 0402 components with my eyes; but I came to some .4mm components and they are too small.
There are tons of stereo microscopes out there, and I was wondering if anyone has any suggestions for good ones so I can go with a trusted model. I am looking for something with a articulating arm; but will go for boom mount. I will spend up to $1000 for a quality one.
Thanks all.
Thu Jul 28 2011, 12:39PM
cheap usb 'microscopes' work quite well and being small can be less hindrance to hand movements when soldering, also you can make .jpg etc.
Bjørn
Thu Jul 28 2011, 12:49PM
Some of the USB solutions have quite a lot of lag that can be disturbing. But they are very cheap, most USB cameras can be turned into a "microscope" by adjusting the focus.
Ash Small
Thu Jul 28 2011, 12:51PM
You might even get away with just using a normal webcam.
EDIT: Bjorn beat me to it.
rp181
Thu Jul 28 2011, 01:31PM
I had looked at that, but I was under the impression that the lack of depth perception would make it difficult.
Thu Jul 28 2011, 06:37PM
How many hours per day do you think you will use it?
If many then the hassle of re-arranging your workplace to fit in a microscope is worth it.
If few then a head-mounted pair of magnifiers may suffice?
From a few dollars to lots!
Don't forget good lighting .. essential.
P.S. research/development/production/maintenance etc.
will benefit from ePhotographs (jpeg etc....what's the generic term?)
So a good camera/microscope will probably be required anyway.
P.C.B.s are usually two-dimensional,
not much to gain with the extra dimension, other than comfort.
P.P.S. with 0402 etc. a usb microscope would allow you to breathe without blowing away your components ;)
What heat source are you using for soldering etc.?
Thu Jul 28 2011, 08:45PM
Someone suggested using a pair of binoculars with the lenses reversed.
-A
Dr. Slack
Thu Jul 28 2011, 09:11PM
The lag through a USB microscope is a killer, and stereo has a lot to recommend it.
Any optical help will be worth having, it doesn't have to be a microscope. Go to your local supermarket or library and get a pair of $3 +4.0 reading glasses, or whatever the strongest is that they sell. I use them all the time to solder small stuff. The only drawback I find is that it brings you about *this* close to the workpeice, so I tend to breathe out steadily while I am soldering to avoid taking the fumes in.
testtest
Sat Jul 30 2011, 01:20AM
testtest Registered Member #3271 Joined: Mon Oct 04 2010, 02:29AM
""I have been soldering .5mm pitch chips and 0402 components with my eyes; but I came to some .4mm components and they are too small.
There are tons of stereo microscopes out there, and I was wondering if anyone has any suggestions for good ones so I can go with a trusted model. I am looking for something with a articulating arm; but will go for boom mount. I will spend up to $1000 for a quality one.""
I have a LOMO Russian binocular microscope. It is a true binocular with two independent optical paths with separate objectives so you get true (magnified) 3D views.
Absolutely fantastic for the kind of work you are proposing.
Look on e-bay if there is one available. They are very inexpensive for the performance.
Here is an example (new) with the trimmings ($595):
Very happy with mine. I taped a cheap UV filter (for a camera lens) to the outside of the objectives to intercept the fumes from the soldering.
It is then easy to clean and protects the optics. I also ended up dumping the cheap illuminatior and replaced it with a fiber optic ring. You can also find LED rings now.
A real workhorse for SMD work and finding bad joints on ICs and PCs. LOMO also has a T mount camera module for it that I use with my DLSR to document stuff.
Pinky's Brain
Sat Jul 30 2011, 09:59AM
Why not just get one of those flip down head mounted magnifiers watchmakers/jewelers/etc use? If you handled just a bit larger by eye the magnification should be plenty.
