  • Guests: 57
RoV IW3IPD (63)
01/13 si2030 (62)
ZVS: I blew a trace =(
Juniortore1
Sun Jul 24 2011, 04:54AM Print
Juniortore1 Registered Member #4014 Joined: Wed Jul 20 2011, 05:31PM
Problem? Not with my handy hands!
What a rig! Why, whats wrong with that? It works!
Thats such a rig! But it works does it not?
Some final touch ups for prevention of overdose
Killa-X
Sun Jul 24 2011, 05:19AM
Hey man, I never had a problem pumping 70V 15A through that thing. So dont blame me on making the traces too small! Something just had a hard short and blew a trace instead of a mosfet.
Least you had a fix. I would have used a copper wire..lower resistance than all that solder. But hey, Least its a fix!
Good luck
haxor5354
Sun Jul 24 2011, 02:24PM
you should of use solderwick to bridge it then cover it with solder
Juniortore1
Sun Jul 24 2011, 03:51PM
Ya, my IRFP150s may have blown when I hit 50V to it, although they handled it many times before no problem. And When I was drawing 5 inch 3/4cm thick arcs, I noticed the PCB was very hot, and this time it was not the 470 ohm resistors getting hot, I believe it were the traces having a hard time. Well, I know what power to keep this board at now anyway.
I didnt use all solder for that, I have copper wires under it with a lot of solder holding it together.
