  • Guests: 38
01/13 si2030 (62)
Final year lab project
Fraggle
Sat Jul 23 2011, 11:19AM Print
Fraggle Registered Member #1526 Joined: Mon Jun 09 2008, 12:56AM
Ha, I was just looking over the research project options for my final year and came across this gem:
Project Title: Thermophone
Project Description: The phenomenon of sound is due to longitudinal pressure waves in a fluid. The most common way of converting an electrical signal into sound waves is to use a loudspeaker, essentially an electrically operated piston that alternately compresses and rarefies the air. Another method of producing sound waves is by alternately heating and cooling the air. A thunderclap is a well-known example of sound produced by rapid heating of air by lightening. The idea of the thermophone is to exploit this heating method to convert an electrical signal into sound. There has been very little previous work on thermophones. Two papers can be found on the web by typing 'thermophone' into a search engine. The aim of this project is to develop a prototype thermophone using techniques and materials available in the lab. It does not need to be high-fidelity, but it should be audible by the unaided ear.
I am ALL over that like a bad smell :D
Adam Munich
Sat Jul 23 2011, 12:55PM
Sounds a lot like a plasma speaker to me smile
Sat Jul 23 2011, 01:22PM
Hiya Fraggle,
this paper on nanofilm thermophone technology is worth a look:
Prevenslik TV, Thermophones and Quantum Mechanics Link2
Fraggle
Sat Jul 23 2011, 02:02PM
I`ll start working through that paper. It has a wealth of juicy-looking references too, thanks.
Pinky's Brain
Sat Jul 23 2011, 02:06PM
Thermal expansion/contraction is the predominant cause of sound creation by a plasma speaker (in theory ion wind could play a part, but not with the HF modulated methods popular here).
I wonder if you couldn't do this much more efficiently by flash vaporizing a low boiling point (or just take water at reduced pressure) liquid as a medium to heat in very small areas. I'm thinking of a big array of small bits (<< 1mm) of nichrome wire. These would then form bubbles in the same way as in inkjet printers (which would rapidly collapse as the power is turned off as the surrounding liquid cools them back down, inkjet heads can work at many kHz).
Sat Jul 23 2011, 02:12PM
Fraggle wrote ...
It has the feel of something that was intended for a journal, but isn't in one (yet?), so be cautious around any contentious-looking statements.*
But it seems useful as a survey of the thermophone terrain, with juicy references to boot!
*EDIT: Woops! I got that one wrong! The paper appears in Thermal and Thermomechanical Phenomena in Electronic Systems (ITherm), 2010 12th IEEE Intersociety Conference on Date: 2-5 June 2010 pp 1-5, but has changed its name from Thermophones and quantum mechanics to Thermophones by quantum mechanics
Fraggle
Thu Oct 13 2011, 06:16PM
Well, no thermophone for me but I did get something good - we have to design an ultra low noise ~10MHz signal amplifier to be operated at 4K. It will sit in a cryostat amplifying the signal from a micromechanical oscillator thingy in there with it. We get to characterise a transistor at 4K and then analyse the performance of whatever we build at 4K too!
All in all it could have been worse!
