  • Guests: 59
IAmSpock (18)
01/30 Ian (37)
01/30 Lucas (40)
01/31 Mathias (42)
HV Flyback Bench Top Power Supply for Lab.
1 2 3 4  last
Fri Jul 22 2011, 06:38AM Print
This device is a permanent labratory (Bench top) type HV SMPS.
Device: Flyback HV transformer Driven by 555 timer and MOSFET, open loop-no regulation.
Purpose: For callibration of HV measurement probes, DeSeversky lifter research, and for HV insulation characterizing.
Features: Oil tank, Thermistor, Line powered (120Vac, 2.5A), 555 timer, FAN 7382N gate drive, MOSFET STW13NK100Z, Large heat sinks, AC low voltage transformer, Flyback transformer primary sees 57Vdc at about 4 amps average (30 Turns).
Components:
STW13NK100Z MOSFET (TO-247)
STmicro NE555N (DIP-8)
FAN 7382N (DIP-8)
Vishay 1.5KE300A TVS
Caddock 0.5 Ohm, resistor (TO-126)
HR 6329, Bought from Killa-X, (inside 1.2 Liter oil tank).
Datasheets:
]fan7382n_gate_driver.pdf[/file]
]mp9000_series_resistor.pdf[/file]
]ne555n_timer.pdf[/file]
]ntc104-rc_thermistor.pdf[/file]
]stw13nk100z_mosfet.pdf[/file]
Some initial specs....
200+ watts... 35kV, 16kHz, 555 timer. I estimate the output currrent to be 5mA, but will measure the output volts and current later today.
using 555 timer, 260 Watts (input), 34uS on, 29.2uS off, 57V @ about 4 amps.
About 15.7kHz (53% Duty Cycle). Temp has so far peaked at 104 degrees F, after a 30 sec run.
strikes every time on two 0.5" ball bearings 1.18" (30mm) apart, almost every time 1.38" (35mm) apart. Should be near 35kV i think
1311323405 2431 FT1630 Top
Overview of whole PS, Canola oil filled flyback tank on right, configured with ball spark gap.
1311322994 2431 FT1630 Flybackp
Flyback oil tank (left), Main caps in blue, circuit board.
1311321931 2431 FT1630 Arc
Hot arc.
1311319153 2431 FT1630 Totaltime
Current profile through flyback and 0.5 Ohm resistor, (Primary current), peaks at 5.8 V, so 5.8V / 0.5 Ohms = 11.6 peak amps.
1311358139 2431 FT120576 Oiltank
Oil tank schematic.
1311358139 2431 FT120576 Power
Power chopping circuit.
1311381922 2431 FT1630 Oilpic
97degrees F, at the top surface of the acrylic tank. The small bubbles on the center and left are from the heat of expansion from oil filling the now hot ferrite gap, the larger bubble on right is for thermal expansion of the oil, the air bubble shrunk about 0.2 inches in overall diameter while at 97 degree F (ferrite is at 118 peak temp F). Time to let it cool off. I do worry that the pressure will blow out the gasket sealer. I may have to replace the four nylon screws with metal screws.
1311359943 2431 FT120576 Hr6329
New pics, case is nearing completion.
1311927961 2431 FT120576 Psbox1
1311927961 2431 FT120576 Psbox2
1311927961 2431 FT120576 Psbox3
radhoo
Fri Jul 22 2011, 08:49AM
Good initiative, but why did you submerge the flyback under oil? I see no advantages other than lowering the temperature on heavy loads.
Fri Jul 22 2011, 09:01AM
radhoo wrote ...
Yes, to keep it cool..
radhoo
Fri Jul 22 2011, 11:06AM
In my tests I've seen that is MUCH better to use concentric primary and secondary coils in a flyback. In this case you would have obtained better energy transfer and larger arcs using one of the primary original windings.
Also since this is a lab supply, why not use a HV resistor to get a feedback from the output, to regulate the output?
Fri Jul 22 2011, 03:23PM
radhoo wrote ...
Absolutely, Radu. I've found that by using the drive circuitry for which an LOPT was originally designed, that hundreds of hours of trouble-free continuous operation results.
Fri Jul 22 2011, 04:41PM
Proud Mary wrote ...
radhoo wrote ...
I have 3 flybacks of the same type, ill trythe original primary then and well see if theres a difference. Arnt the normal primaries meant to run off 90 or more volts though? if i could find a schematic that would make it easier.
Fri Jul 22 2011, 06:02PM
Patrick wrote ...
radhoo wrote ...
Generally between 90 & 110V.
Here is a typical basic circuit:
1311357630 543 FT0 Lopt Circuit
Fri Jul 22 2011, 06:08PM
Patrick wrote ...
radhoo wrote ...
ill try the original primary, but its hard to figure out, there are 8 different pin combinations which reveal 0.3 to 0.6 ohms, and Killa-X and i have no way of knowing the number type.
New pics!!!
Fri Jul 22 2011, 06:13PM
Patrick wrote ...
Are there no numbers on the LOPTs that we could cross-reference in the HR Diemen catalogue?
Added afterthought: it isn't unusual for an LOPT primary to have several auto-transformer taps on it - the idea with modern LOPT design is to supply power to as many sub-circuits of the whole TV or monitor as possible.
Fri Jul 22 2011, 06:16PM
Patrick wrote ...
From PM, Killa-X :
"I wont know anymore about them than you would, seeing i bought them on ebay as a "Factory Outlet" meaning, my spend on 24, all 24 could have been dead. they are all rejects for whatever reason. At least, thats what the seller claims. All 24 do work. I only had 3 that came shipped with 100% smashed cores.
I have tried searching the info on them with whats listed and found nothing sadly. Says TCE 70234 Feb 205 2:01
then theres a ba code. My phone says its:
70234509789660 which brings nothing on google."
My label says :
2G25023 A1A
TCE 35.0 Kv
RXE
1 2 3 4  last
