  • Guests: 32
Thomas (40)
VulcanBB18 (50)
07/19 Thomas (40)
07/19 VulcanBB18 (50)
07/20 rev (49)
My SGTC FailCoil
Tetris
Thu Jul 21 2011, 11:14PM Print
My tesla coil is very much a fail coil. Even with a grounding stick near it, it only makes an inch of a spark, without, nothing comes. I had imagined a million volts arcing across garage when I first planned to build it. Even if I am not able to achieve that, what can I do to make my 16 inch ,3.5 inch diameter coil with a 7.5kV 30mA NST and leyden jar caps work before school starts (August 22)?????? :D
TeslaCoil
Fri Jul 22 2011, 12:51AM
TeslaCoil Registered Member #4020 Joined: Thu Jul 21 2011, 06:40PM
Did you use any guides to build this? Or do you just already know how to perform the correct equations?
magnet18
Fri Jul 22 2011, 03:59AM
You definatley need to make sure it's tuned to the correct frequency and everything, resonance is key
Look through this -http://deepfriedneon.com/tesla_guide.html
and this-
and you should be able to get streamers a good foot or so with some minor modification.
Dr. ISOTOP
Fri Jul 22 2011, 05:54AM
As everyone else said, tune for resonance: L_pri * C_tank = L_sec * C_sec, where C_sec is the self-capacitance of the secondary + the capacitance of the topload.
Secondary specs?
genious 7
Fri Jul 22 2011, 04:00PM
genious 7 Registered Member #2887 Joined: Sat May 29 2010, 11:10PM
Specs?
Secondary, Primary, resonant freq; pictures may help too.
TeslaCoil
Fri Jul 22 2011, 04:06PM
Yeah, I've seen people on YouTube with these makeshift tesla coils that don't do anything but hum unless you put a grounding wire near it. Look through the guides on DeepFriedNeon, they are very helpful and that's how I'm designing my first SGTC.
Tetris
Sat Jul 23 2011, 04:53AM
Michael Chen wrote ...
Specs?
on youtube: awesomelightning
videos. they are the most recent so land on channel and screen will be one of four.
