  • Guests: 50
MY CARE PACKAGE HAS ARRIVED >:D
haxor5354
Wed Jul 20 2011, 04:07AM Print
yay I order an box load of cheap stuff from China last month and now its here!
bough four 50A SCRs that can handle 500A surge for 10ms, that should be enough for my coil gun project. = $5.15
200w SMPS for arc lamps + a 200w arc lamp (prabably got mercury in it) = $30
badass jet lighter that can a blow 4" flame = $7.50
50w HID flashlight w/11.1v 7800mAh li-on battery = $128.79
a box of 200 piece 1N5408 rectrifier diodes = $3.33
20110719224923343
looks quite beefy
20110719224903735
200w SMPS for the arc lamp
20110719224609349
DAMN THATS HELLA BEIGHT
20110719230122773
too bad I didnt see this 0-30v 7.5A DC-DC converter last month, could have bought that but didnt know about it back then.
check out this beast Link2
if you can't read the chinese, (luckly I still can) it says its got
-adjustable voltage & current regulation (<0.7ms reaction time for voltage <0.4ms for current)
-buck-converter style DC-DC conversion with 96% efficientcy
-12v to 50v input (9v cutoff)
-less than 50mV peak-peak ripple under 30v 7A load!!!
this is gonna make a beefy lab PSU. for $49 chinese, THAT ONLY $7.59 USD!!!!1 what a steal
can't order anything till next month sad o well I can always wait for that.
Wed Jul 20 2011, 05:49AM
So is the site like a Chinese ebay? I want to order something off alibaba. Does anyone have experience with the site? Seems legit.
haxor5354
Wed Jul 20 2011, 05:59AM
i dont think you can order just 1 item from alibaba, you gotta order in large quantities.
Wed Jul 20 2011, 07:19AM
My SCRs are better than your SCRs... cheesey
1311146361 2431 FT120388 Scr
haxor5354
Wed Jul 20 2011, 07:44AM
mine cost less than $2 a piece and yours cost $20 at digikey.
bet I can get 10 of mine in parallel and out perform 1 of yours wink
Wed Jul 20 2011, 09:38AM
I've bought all sorts of bits and pieces from China over the years, and have never had any reason for complaint. Besides, most of the world's manufacture of electronic components is now done in China, so it makes sense to go the source, rather than buy the same part for much more from middle men outside China.
Wed Jul 20 2011, 10:09AM
This is my shipment from ebay... 40N120 ultrafast IGBTs (64/40A 1200V, 110/40ns fall), $2.7 a piece
1200V 30A fast diodes, $2.1 a piece
1311156545 152 FT120388 P242
Jrz126
Wed Jul 20 2011, 11:05AM
Weston wrote ...
I've bought some stuff off it before for work. Just email the seller and ask if you can order a few samples.
Patrick wrote ...
I think I win tongue
Scrs
Wed Jul 20 2011, 09:11PM
Your all a bunch of cowards, im tyaking my ball and going home! cheesey
(9 years ago i got mine for like 4$ each, 50RIA60)
haxor5354
Wed Jul 20 2011, 09:24PM
what happens if I use a 200w ballast on a 120w ultra high pressury mercury lamp? would it over heat and explode?
