  • Guests: 52
RoV IW3IPD (63)
01/13 si2030 (62)
very low power hv supply?
alf
Tue Jul 19 2011, 06:06PM Print
alf Registered Member #3925 Joined: Fri Jun 03 2011, 10:50AM
hey,
any ideas how to build a variable (not essential) 1-5kv supply, which can run from a 9v battery, and will use a very maximum of 10W? its for my tiny crt oscilloscope anode voltage.
thanks. Alf.
Ash Small
Tue Jul 19 2011, 06:20PM
A DC flyback, maybe?
Maybe driven by a transistor?
Tue Jul 19 2011, 06:35PM
Xenon flash transformers are often very compact - miniature - low powered, inexpensive, and easy to find.
I'd suggest you first get hold of the CRT data sheet, so you know exactly what your power supply requirements will be.
Tue Jul 19 2011, 09:28PM
A 555+transistor, little mains transformer in reverse and a few stage cw multiplier.
Tue Jul 19 2011, 10:31PM
Dr. Kilovolt wrote ...
I don't think Alf's 9V battery would last very long with a setup like that - not an ordinary PP3 one, anyhow - and, in any case, PP3 and the 10W mentioned by Alf don't really hang together, do they?
Forty
Tue Jul 19 2011, 11:35PM
555 driving a transistor driving a ccfl transformer might work.
Juniortore1
Thu Jul 21 2011, 06:29PM
Juniortore1 Registered Member #4014 Joined: Wed Jul 20 2011, 05:31PM
Maybe a ZVS ballasted by a 10W light bulb or something. Very cheap if using low power parts, and heat free.
Forty
Thu Jul 21 2011, 06:47PM
does the zvs work fine with non-flyback transformers? like ferrite e-cores and pot cores. I imagine they do, but i haven't tried. you could probably make a little hv low power transformer with those. a ccfl inverter transformer would be the easiest premade transformer
hboy007
Thu Jul 21 2011, 07:28PM
CCFL inverter + villard cascade maybe?
radiotech
Thu Jul 21 2011, 07:38PM
As Proud Mary said, get the CRT data sheet up front.
Also, what is going to light the heater of the CRT ?
It its mains, then a transformer/multiplier might be used.
