  • Guests: 32
Billybobjoe (35)
07/19 Thomas (40)
07/19 VulcanBB18 (50)
07/20 rev (49)
SSTC help
genious 7
Fri Jul 15 2011, 02:37AM Print
genious 7 Registered Member #2887 Joined: Sat May 29 2010, 11:10PM
I am planing to build my first solid state coil, and wanted to ask some questions. Probably something along the lines of Steve wards SSTC5. I was reading and wanted to ask about the antenna placement. Is there any special consideration I must take or is it "just placed there". Any phasing considerations I must take, or any other thing to consider?
2'nd point: I haven't been able to find a suitable ferrite core for the gate drive transformer. Is there any foreseeable problem with using a gate drive chip (I've found IR2110). I know I will lack isolation and I will need to introduce the starting circuit, since this is provided by the inverting driver (that I couldn't obtain, no UCC line over here)
If possible, I'd like to obtain all locally, as importing is expensive(and a bit slow) here on Panama. I haven't provided many details as I'm still deciding on factors. Any other tips I should consider for my first SSTC?
Dr. ISOTOP
Fri Jul 15 2011, 02:47AM
The IR2110 may not be capable of driving large transistors at high frequency.
genious 7
Fri Jul 15 2011, 02:16PM
Not sure if on purpose, but it is going to drive Mosfets, not transistors. something along the lines of IRFP260. Nevertheless, I am a bit worried about the frequency. Do you think this could be a problem?
If not, I have heard one can use the transformers (EI) from computer power supplies, but all I have seen are glued together. Do these transformers work? If so, how do you split them apart without breaking them? (Tried once, broke it)
Again, any special considerations or tips about the antenna?
Polonium210
Fri Jul 15 2011, 03:44PM
Polonium210 Registered Member #3450 Joined: Sun Nov 28 2010, 05:01AM
I had tried the EI core once with no success. I used a cup of boiling water to melt the glue.
Try finding a CRT computer monitor, they have a nice toroidal core on the flyback wires.
Forty
Fri Jul 15 2011, 08:44PM
a mosfet is a just a special type of transistor. ferrite toroids should be very easy to find. crt monitors, TVs, computers and their power supplies, audio equipment, etc. will all likely have them. look for bundles of wires twisted through them.
genious 7
Sat Jul 16 2011, 11:06PM
Thought those were powdered iron toroids.
Polonium210
Tue Jul 19 2011, 12:39PM
The powdered iron ones are painted blue/white or yellow/white. Look for the black ones. The first good one I found that worked came from a CRT monitor.
