  • Guests: 78
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Who need balls? :-)
Patric
Tue Jul 12 2011, 04:21PM Print
Patric Registered Member #2899 Joined: Wed Jun 02 2010, 06:31PM
Found in a pet shop in Belgium, Astene... beautiful balls to use as top-sphere on a Tesla transformer. 15€ for about 15 cm ( 6 inch) diameter.
1310487689 2899 FT0 Dva
Killa-X
Tue Jul 12 2011, 04:36PM
Nice find, best luck I had here was finding 12" diameter styrofoam balls and smaller. Just means you have to put aluminum tape on it, big deal, point is its a near perfect sphere for cheap cost to make a topload perform just as any aluminum one would.
Tue Jul 12 2011, 07:58PM
They are known as gazing balls to put in garden ponds.
They can be found cheap on ebay
RogerInOhio
Wed Jul 13 2011, 01:40AM
RogerInOhio Registered Member #1034 Joined: Sat Sept 29 2007, 12:50PM
What are they made out of ? I don't like the glass ones very much.
Patric
Wed Jul 13 2011, 06:15AM
They are made of inox, they are just a little bit magnetic.
Wed Jul 13 2011, 07:09AM
The gazing balls i have seen are made of stainless steel
Patric
Wed Jul 13 2011, 10:48AM
In metallurgy, stainless steel, also known as inox steel or inox from French "inoxydable", is defined as a steel alloy with a minimum of 10.5 or 11% chromium content by mass. So they are high quality!
Ash Small
Wed Jul 13 2011, 01:33PM
I have one that I believe is 300 series austenitic stainless steel, which is not magnetic. I think it is 316, if I remember correctly, probably 316L.
Patric
Wed Jul 13 2011, 06:06PM
Can the material of the ball be of influence on the Tesla coil?
