  • Guests: 75
Steve Ward Single 833A Design - Resistors
Download
Tue Jul 12 2011, 03:39AM Print
Download Registered Member #561 Joined: Sat Mar 03 2007, 02:46AM
So I now have nearly everything for my first VTTC; wire, caps, transformers, variac, etc. But I'm having trouble getting a 100w 5k wire wound resistor, I've tried eBay but no one has any values over a couple hundred Ohms, nothing near the 5k I need. I considered winding my own I would need a lot of nichrome wire for that (say a couple hundred metres?). Any suggestions? I'm in Australia if that is useful
Secondly, L4 in the schematic is wound over a 30R resistor, what kind of wattage should it be? I'm guessing >50w. I also see a slight problem with this, if I have a bigger or a smaller resistor the value of L4 would change dramaticly. Any ideas to what sort of inductance it should be?
Cheers
Tue Jul 12 2011, 04:26AM
Link2 And you can heatsink it :P It isn't variable, but you could use different capacitor values instead.
The inductor and resistor are a HF filter. It helps keep any ringing out of the tube. The ideal inductance depends on the frequency, but it isn't particularly important. You don't need to wind the inductor over the resistor, just try to make it close to Steve's just to be safe. The resistor wattage isn't important, it won't be dissipating much.
Inducktion
Tue Jul 12 2011, 05:36AM
Download, I have some 5k 50 watt resistors. With some parallel and series magic I think you could get the right number..
Download
Tue Jul 12 2011, 06:44AM
I imagine a resistor covered in aluminium won't be very good above 1kV. With the inductor though, will a little 10w wire wound do?
Inducktion - How much do you want for them? I imagine 50w should be fine if I keep the running time low anyway. I don't have the money to build a Staccato anyway so I'll have to
Dr. Drone
Tue Jul 12 2011, 04:06PM
shades
Download
Wed Jul 13 2011, 01:39AM
Alright, I won't bother with that resistor and just use an inductor wound on a piece of PVC or something.
I found a 15k, 225 watt on eBay, any problems with that?
Edit:
I've found a dirt cheap 75k resistor, might be too high though
Dr. Drone
Wed Jul 13 2011, 03:22PM
shades
Download
Fri Jul 15 2011, 02:46AM
I found 10x 51k 90w resistors for $25
Sounds like a good deal, I can run them in parallel and get a large number of values
If I have 10 I can butcher one and try make it variable
