  • Guests: 40
microwave oven transformer buzzing loudly
alf
Fri Jul 08 2011, 07:14PM Print
alf Registered Member #3925 Joined: Fri Jun 03 2011, 10:50AM
hey,
yesterday i removed the secondary, the filament wires, and the magnetic shunts etc.
from my MOT, and today i did a test my winding a secodary,
and everything seemed fine, till i realised, that, at 60v input (using variac) the current drawn when the transformer is idling, is 0.15A
and at 120v, it is 0.3A, but after about 200v, the current rises dramatically, and at 240v in, it is drawing 5A!, and the core, and primary are heating up, although not *too* much, i tried grounding the core, it didnt help :S
maybe there is an arc, or insulation breakdown? :(
there is a twist though, when i measured the power with my power meter, it read 177 watts, at 5A, 240V
maybe something irrelevant to do with power factor?
thanks. Alf.
Chip Fixes
Fri Jul 08 2011, 07:26PM
Your MOT is getting saturated, the more voltage you put into it, the faster it will saturate and the more amps it will waste as heat energy. Try using a ballast
alf
Fri Jul 08 2011, 07:49PM
Camp Badger wrote ...
hey,
AWESOME!, so this means that is is working?
a resistive ballast, or an inductive one?
thaaaanks. Alf.
Fri Jul 08 2011, 08:12PM
The problem with MOTs is that they use huge flux density, and are already beyond saturation at "rated" voltage. Removing the shunts makes this even worse. Try winding around 20% more turns, or use a series step-down transformer (a "buck transformer").
AleSeg
Fri Jul 08 2011, 08:21PM
AleSeg Registered Member #2727 Joined: Tue Mar 09 2010, 02:39PM
Do not worry about the transformer, which has no any short circuit.
The quick explanation for this phenomenon is: these transformers were made to cost little money and be used in intermittent conditions and full power. Too much flux density.
Furthermore, as the transformer is at no load condition in your test, I would not rely much on reading the power or ampere meters if they aren't true RMS meters, because the current harmonic content is enormous.
See you :)
Chip Fixes
Fri Jul 08 2011, 09:21PM
alf wrote ...
hey,
thaaaanks. Alf.
Yes it works, I would use an inductive ballast
EDIT: If you have another MOT you can use it as a ballast, ton of tutorials online for that
Adam Munich
Sat Jul 09 2011, 12:20AM
Actually, every time I've measured an MOT I meter a no load (magnetizing) current of 5 amps or so. 60hz transformers are crap like that, and that's why we use switch mode supplies now.
alf
Sun Jul 10 2011, 06:48PM
Grenadier wrote ...
ahh right,
of course P=VI, doesnt apply here, cuz although in theory it should be using over 1kw, it is only using 180w!
so it aint as bad as i thought lol
i have wound about 6 meters of mains cable on the transformer (20cm per turn, if the wire could cling to the laminations perfectly) and i am getting about 24v, so now i must squeeze another 3 meters of wire in to this critter :D
i am winding it, with taps, so it will supply 12, 24 or 36v to my zvs driver, (dont wanna wear out the fbt unneccessarily)
i have this image in my head of it all being in a nice wooden box with knobs and buttons on it, but itll probs end up, as always, in a tangled heap of wires hahaha
btw has anyone tried discharging a hv cap through a piece of nichrome wire?
it gives a nice effect, if the voltage is high enough to melt the wire, it breaks into hundreds of glowing balls of metal. lol.
thanks. Alf.
