  • Guests: 69
01/20 CT2 (37)
01/20 Josh Johnson (46)
01/21 Banana Man (41)
Need design for H bridge
Pankaj Patel
Fri Jul 08 2011, 06:05AM Print
Pankaj Patel Registered Member #2581 Joined: Tue Dec 29 2009, 09:08AM
Hi to everyone,
Can any one help me out for design the hardware for Half and full H bridge, whose specification as below.
Switching speed :- 110 to 500Khz.
Voltage :- 19 to 100VDC.
Amp :- 4 to 25 Amps.
I am asking help for the H bridge because i don't have any experience for mosfet and driving. I am good in the microcontroller.
Please someone help me.
Dr. ISOTOP
Fri Jul 08 2011, 06:48AM
Bridge design bridge design bridge design!
So you want 500 Khz...this implies MOSFETs not IGBTs.
At 500 khz each cycle is 2uS. You want switching time to be no more than 10% of this, so your FET's switching time must be no more than 200 nS.
You want 100V on the bridge, so get FETs rated for 150V or something...pushing voltage too close to the max ratings causes the transistors to avalanche a lot and become sad.
Leave some headroom for current, though this is less important.
TVS's and snubbers are your friends smile
Pankaj Patel
Fri Jul 08 2011, 06:54AM
Thanks for guide, but what about the driver section which will drive the mosfet. please help me in this section also.
Fri Jul 08 2011, 07:45AM
a couple of LM5102 driver chips from National should be able to sort the problem.
What is the load you intend to drive?
-Finn Hammer
