  • Guests: 46
Noelle (43)
King_of_Junk (36)
Ixz (35)
geobruce (31)
tulkas (32)
Gregory (31)
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Mini SSTC finally complete
Polonium210
Sun Jul 03 2011, 02:24AM Print
Polonium210 Registered Member #3450 Joined: Sun Nov 28 2010, 05:01AM
After a long while off of 4hv I have finally figured out my problems with my version of Steve Ward's Mini SSTC5.
Here is a link to my original thread Link2
I knew very little about electronics when I first started this project, but have come a long way since. I went through several different driver boards and many blown components as well as a few different size secondary coils to figure out what works best.
I think I have made a big improvement with this coil.
Here are some spark pictures
And the beefy bridge (Way overkill for such a small coil)
Movie
And I was even able to audio modulate it with an arduino
I modified Steve's schematic and printed a proper board with ExpressPCB, a very easy program to use in my opinion.
The main problems I had with this coil was not having the correct GDT core material, my control transformer was too small and my bridge design was very sloppy.
Dr. ISOTOP
Sun Jul 03 2011, 10:24AM
Holy sh*t that's a lot of minibricks.
Beautiful coil! What are the specs (frequency, power, etc)?
TheBoozer
Sun Jul 03 2011, 01:30PM
Perfection...
I have only 1 question. Are those mosfets? Could you share the part #?
Rich
U4R1A
Sun Jul 03 2011, 08:13PM
U4R1A Registered Member #3505 Joined: Sun Dec 12 2010, 06:03AM
Awesome work. I'm also interested in your specs.
Sun Jul 03 2011, 08:28PM
TheBoozer wrote ...
Perfection...
Rich
He mentions its 600V IGBTs in his photostream ( Link2 ) my guess would be IXGN60N60C2D1
Polonium210
Mon Jul 04 2011, 06:31PM
Ah yes, I forgot to post the specs.
The secondary is 3" by 7" wound with #30, Fres is around 580KHz.
Double stacked John Freau toroids
Power side is 120v wall outlet at around 9A, so just over 1000Watts. This goes into a variac that ups it to 140v and then into a step up transformer for a final voltage of 275VAC ~ 388VDC buss voltage into a halfbridge of IXGN60N60C2D1 IGBT's.
Like I said, a little overkill for such a small coil.
