  • Guests: 35
First VTTC possible resonance issue
christensenda
Mon Jun 27 2011, 11:59PM Print
christensenda Registered Member #3062 Joined: Wed Aug 04 2010, 02:07AM
I just recently finished building my first VTTC, it as an 811A and I used steve wards design however, I have tried with and without a Bypass capacitor connected to the leads of my MOT power supply. Or perhaps, my primary doesnt have enough turns in order to resonant with my secondary coil form.
1309219147 3062 FT0 Vttc
teravolt
Tue Jun 28 2011, 03:36AM
c2 190pf seems a little low have you tried anything else like 2200pf? In reality your primary circuit should be resonant with your secondary. Do you have a o-scope and signal generator if not a simple detector with meter and a 555 oscilator circuit might suffice for tuning
christensenda
Tue Jun 28 2011, 04:32AM
Im afraid I dont have an oscilloscope or signal generator at my disposal. by chance, would the capacitor that came with the MOT work for my tank capacitor C2, its rated at 2100VAC at about 0.84uF ?
Patric
Tue Jun 28 2011, 07:42PM
Patric Registered Member #2899 Joined: Wed Jun 02 2010, 06:31PM
This is my circuit from a Tesla coil with one 811a. Now I am making my secondary coil, and then I will measure the resonance frequency, to determine the primary coil and capacitor.
Success with yours, and keep us informed!
1309290125 2899 FT118739 Tesla811adef
Patric
Tue Jun 28 2011, 09:09PM
In the mean time, I calculated the resonance frequency, and it is 610 kHz without, and 460 kHz with torus 15 cm.
christensenda
Wed Jun 29 2011, 01:12AM
I tried increasing the capacitance to 6KV at 2.2nF still no luck so far. Will a VTTC still produce little sparks if poorly tuned like a poorly tuned SGTC ? or will it not produce anything and not resonant whatsoever
teravolt
Wed Jun 29 2011, 03:47AM
c2 is going to have to be a doorknob cap or a russian ceramic cap and preferably mica caps. any of those should handle the primary tank frequency and have a low ESL and ESR. you may need some basic equipment a multimeter, frequency counter and a pulse generator, you can make a pulse generator with a 555 and mic4429 fet driver. a detector made from a 1n34 and capacitor can be used to determine amplitude. your primary must have the same or 10% lower frequency than your secondary you will need some basic equipment. do you have any pictures
christensenda
Wed Jun 29 2011, 04:55AM
I do have a picture or two of my VTTC so far. As far as the parts you suggested I use I have very limited equipment and electronics at my disposal, I am about to be a junior in college, and just an amateur enthusiast at best. I could order those those several parts but that may take awhile.
1309323048 3062 FT118739 Gedc0058
1309323277 3062 FT118739 Gedc0057
Wed Jun 29 2011, 07:57AM
1. Try swapping the connections of grid coil
2. Calculate resonances and tune ! Make a tapped primary, get a proper RF ceramic capacitor with kVAr rating or make a MMC out of MKP/FKP caps.
teravolt
Wed Jun 29 2011, 07:48PM
have you seen the thread by hsieh
