  • Guests: 44
heatsink for soldering
LD LANGER
Mon Jun 27 2011, 07:29PM Print
LD LANGER Registered Member #3824 Joined: Sun Apr 10 2011, 08:29PM
Hi, has anybody ever tried to heatsink the leads of components while they are soldering? I am soldering a string of 1n4008 diodes and they are getting VERY hot even when only touched for a second or two. Is there any good way of heatsinking the leads so as to not destroy the diodes?
Thanks,
Daniel
Mon Jun 27 2011, 07:39PM
I find forceps Link2 really useful for holding wires or components still whilst soldering and they act as quite a good heatsink.
A very useful tool for general grip.
Ash Small
Mon Jun 27 2011, 08:20PM
I use thin nosed pliers, or larger pliers for larger components. (also stops you burning your fingers)
lightlinked
Tue Jun 28 2011, 05:39AM
lightlinked Registered Member #2087 Joined: Tue Apr 21 2009, 08:32AM
Some people use alligator clips as lead heatsinks during soldering, There are heat sink clips avalible but they should be unnecessary for making a diode string. How are you going about assembling them? I've seen some people bend the leads into hooks where as I just clip the leads to length and solder them by having a blob of solder on the iron tip. Although that only works if the leads are fresh/not oxidized, otherwise they need more heat/flux. What kind of soldering iron and solder are you using?
LD LANGER
Tue Jun 28 2011, 05:54PM
Actually I just put 4 alligator clips on the leads and they took the heat very well, much better than expected!
Adam Munich
Wed Jun 29 2011, 02:46AM
LD LANGER wrote ...
Diodes and most other components are built to withstand the heat of soldering. After all, in the real world they are either baked at very high temperatures or sent over a waterfall of molten metal...
teravolt
Wed Jun 29 2011, 02:58AM
use a 800degF iron and it won't take so long to make the joint
ConKbot of Doom
Wed Jun 29 2011, 11:57AM
If you can do the joint in 5 seconds or less, you should be fine. If its taking more then 5 seconds, you need a bigger soldering iron tip (more thermal mass, more contact area) or a higher soldering iron temp. Careful with a higher temp though, as it makes overheating easier if you do go past the 5 seconds. All this is assuming your tip is clean, and holds a tin well, so it can make a "solder bridge" to the part for thermal transfer.
Obviously the 5 second rule doesnt really apply as much when it comes to bigger stuff. But if you had an iron capable of doing so, it really wouldnt hurt.
