  • Guests: 42
CW multiplier capacitor
currentkills91
Mon Jun 27 2011, 05:39AM Print
Am I able to use polystyrene capacitors for a CW multiplier? Such as these
Dr. ISOTOP
Mon Jun 27 2011, 07:50AM
Yes.
Mon Jun 27 2011, 12:17PM
Yes but .... from memory, the voltage rating applies when under oil, encapsulated etc.
In air they will probably flash over at 30 kV due to humidity/condensation/contamination etc.
i.e. surface-tracking.
Mon Jun 27 2011, 04:29PM
I second that on humidity, just had a small 9V gas igniter module which arced nearly 4" across a glass bulb and bit me.
Normally it arcs less than 1cm.
-A
