  • Guests: 48
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Kite lights step-up
TheMerovingian
Tue Jun 28 2011, 11:33AM
TheMerovingian Registered Member #14 Joined: Thu Feb 02 2006, 01:04PM
You are right. It is simpler to PWM the led directly from the PIC :D
Bored Chemist
Tue Jun 28 2011, 06:38PM
Duty cycle is the ratio of the time it is switched on to the time it is switched off ( as a percentage). A zero % duty cycle means that it is never switched on. If it still lights up, even when it's never switched on, then you have a free energy machine.
lightlinked
Tue Jun 28 2011, 08:48PM
lightlinked Registered Member #2087 Joined: Tue Apr 21 2009, 08:32AM
If you go to a local hobby shop you can get a little 2 (7.4 volt) cell Li Po battery and a 5 volt buck converter. All super lightweight as they are designed to fly.
I would second the boost converter options. sparkfun and many others have a couple, tiny, boost converters however you would also want a low voltage cutoff if you use Li Poly/ion
TheMerovingian
Tue Jun 28 2011, 08:54PM
Bored Chemist wrote ...
In a boost converter if the duty cicle is 0% the output voltage is equal to the input voltage less one diode drop (this voltage is sufficient to light the led, power is drawn from the input and some is lost in the diode, no free energy) (source: power electronics handbook and common sense)
