  • Guests: 66
Painting Limestone
Chip Fixes
Tue Jun 21 2011, 06:44PM Print
We need to paint our downstairs walls, it's all limestone and they are usually damp from moisture... does anyone have any idea's for paint that would last? would epoxy work?
1308681872 3781 FT0 Wall
Ash Small
Tue Jun 21 2011, 07:06PM
You don't want to use a paint that seals it, limestone needs to breathe or it cracks in the cold, so epoxy and gloss paints are no good.
The best thing to use is limewash (whitewash). I'll try and find a link, but it is basically lime and water.
(My parents had all sorts of problems after sealing the limestone walls in their house. I did warn them, but parents never listen....)
EDIT: I found an informative link:
(BTW, Older houses like what I assume yours is are designed for a real fire, this helps to dry out the damp in the limestone, something else that my parents didn't seem to appreciate.)
Chip Fixes
Tue Jun 21 2011, 08:07PM
thanks! that's just what i was looking for!
EDIT:
Ash Small wrote ...
What do you mean by a real fire?
Avalanche
Tue Jun 21 2011, 09:10PM
Sorry to be off topic, but am I the only one who looked at that pic and thought "that looks like a nice view over some distant mountains, with a cliff in the foreground"
Nicko
Tue Jun 21 2011, 10:25PM
Be aware that lime is pretty evil on the hands. Wear protective gloves else you'll lose your fingerprints...
I speak from experience frown I re-pointed part of an old lime-mortared wall we have. Didn't notice the damage until about 45 minutes in when blood started seeping through what little was left of my fingertips... Took weeks to heal.
Coronafix
Tue Jun 21 2011, 10:55PM
Avalanche wrote ...
Lol, I did too.
Ash Small
Tue Jun 21 2011, 11:43PM
Maybe I should add that any wall, etc. that was built using lime mortar should NOT be repaired using cement based mortar.
Nicko's points are also valid, but once dry, lime turns to carbonate as it absorbs CO2 from the atmosphere, so it doesn't remain a hazard. Lime based mortar and limewash don't keep indefinitely, for the same reason.
