  • Guests: 43
Differences between MOSFETs
currentkills91
Tue Jun 21 2011, 10:24AM Print
Okay, so I was building a tiny little zvs cap charger, and I was just wondering, how much of a difference in performance would I see if I went from a 200v MOSFET to a 150v MOSFET? Now i'm just interested in what would happen if I changed the MOSFETs voltage rating, just assume all other ratings stay the same...
Daedronus
Tue Jun 21 2011, 02:22PM
no change at all?
If you get over the voltage rating you destroy the mosfet, if not, you are doing fine.
Unless is a short avalanche event, but that only happens with flyback mode drivers.
ZVS is a transformer driver, but it's not a flyback mode driver.
ZVS is push/pull, so you need to stay 100% of the time under the mosfet voltage rating.
Just get the lower RDSon mosfet you can get, that has a voltage rating of about 4x of the input voltage.
currentkills91
Tue Jun 21 2011, 02:35PM
Okay thank you (: I just wasnt sure as it seems everyone uses 200 volt fets...so ill actually op-out for 100 volt ones...thanks again
