  • Guests: 46
Is this correct?
Patric
Thu Jun 16 2011, 06:38PM Print
Patric Registered Member #2899 Joined: Wed Jun 02 2010, 06:31PM
Before building my first VTTC, I really want to know if this diagram is correct.
1308249416 2899 FT0 Tesla811
Will this work? Thanks in advance!
Thu Jun 16 2011, 10:21PM
Hello Patric,
the basic VTTC circuit is this: Link2 (by Steve Ward from Link2 )
The basic components are the primary coil which forms a tuned circuit with primary (tank) capacitor, and a feedback (grid) coil with somewhat less turns of thinner wire than the primary, with the grid leak RC circuit.
The RL rf blocking element on the plate is usually not needed for a single tube.
Fri Jun 17 2011, 05:57AM
You can find the original drawings in the magazine Science Experimenter from fall 1963.
Patric
Fri Jun 17 2011, 08:57AM
Thanks for the replay, I know the original scheme, but this one I got from:
I simply did redraw it to better understand it...
I do not want my 811A load too heavy, the circuit must work for several hours.
Fri Jun 17 2011, 09:13AM
The basic VTTC circuit I posted is a class-C oscillator, it is the most efficient self-excited oscillator you can make with a tube (around 75% efficient) and when properly tuned, will do what you want; there is no reason to use a more complicated circuit.
The schematic you posted in your original post, will not work.
PS. If you don't want to use two separate windings, it is possible to reconfigure the oscillator with a tapped primary. Plate goes to one end of the winding, grid is connected to the other winding end through a grid leak capacitor (which must be properly rated voltage-wise). The grid leak resistor goes from grid to cathode. The plate supply goes to the tap.
Nah
Fri Jun 17 2011, 06:00PM
Nah Registered Member #3567 Joined: Mon Jan 03 2011, 10:49PM
In the original schematic, you have the B+ directly connected to the grid. This would burn it up instantly.
Patric
Fri Jun 17 2011, 06:20PM
Then this circuit is wrong!!!:
Fri Jun 17 2011, 06:23PM
The schematic is badly drawn; he has the cathode connected to the negative point of the plate supply (which you do not have in your circuit).
The coil from the link might work, however the circuit is badly designed and will probably operate inefficiently.
Patric
Fri Jun 17 2011, 07:01PM
I really do not see it, but nevertheless, I will follow your good advice, and use the circuit from Steve Ward.
But can I use the 811A directly on the transformer, without diode (D1) or capacitors (c3 and c4), to become a lower tension and save my precious tube?
Fri Jun 17 2011, 07:06PM
Yes you can do that. But you should include the rf bypass capacitor on the supply rails.
