  • Guests: 44
arsg motor starting.
LD LANGER
Wed Jun 15 2011, 07:21PM Print
LD LANGER Registered Member #3824 Joined: Sun Apr 10 2011, 08:29PM
Hey everyone, I am about to run the first test of my rotary spark gap and I just have a question regarding starting it. It is one of those 1/4hp marathon motors. Coupling the disk to the shaft was a pain in the ass but I think its on there (unknown how much force it can take). Anyway, I have a variac that I'm planning on using to start it, but I am having some thoughts on what kind of inrush I'll be expecting.
If I start my motor form a variac and slowly ramp the voltage up, will I be seeing rather large currents when the voltage is that low? I know the speed of the motor depends solely on frequency, but I want to limit the inrush somehow (obviously not using any variation of a VSD).
Is it better to be starting the motor directly from the mains line through a switch, or through my variac? The load on the rotor is essentially zero (just my polycarbonate disk with brass electrodes).
Thanks for the help,
Daniel
Eimac 4-1000
Sun Jun 19 2011, 01:03PM
Eimac 4-1000 Registered Member #3902 Joined: Fri May 20 2011, 08:55PM
Im not familiar with that motor, if its ac induction you can ramp it up with a variac to your line voltage. Polycarbonate is not the best route for disk material. G-10 phenolic would be better. I would also use some kind of saftey shield. AC/DC universal motors from Dayton work good for Async spark gaps. 120volts to the Variac then run a full bridge rectifier and you can vary your breakrate with the Dayton.
Best Regards Jeff
kd4lyh
LD LANGER
Tue Jun 21 2011, 10:36PM
well I have already fashioned my disk of acrylic / polycarbonate (not exactly sure the chemical compound). I am hoping this will not blow to pieces when I turn it on! Oh well. I think if this coil fails to work very good I will just turn to SSTCing.
Tue Jun 21 2011, 11:49PM
Based on some google searches and a very informative pdf, your motor will probably pull around 37.5-50 amps. According to Marathon electric's website, your motor pulls 5 amps at full load and is a split phase motor, and this pdf Link2 says that typical starting current is 750-1000% normal current, and starting torque is 250-350% normal torque.
A bit off topic, but it is interesting that shaded pole motors like in microwaves are typically below 20% efficient! Might as well use a tiny internal combustion engine (not really).
Forty
Tue Jun 21 2011, 11:58PM
isn't this the sort of thing that ac motor start capacitors are for? such as those in washing machines and ceiling fans. i think you could also use a big ballast inductor to limit the initial current inrush.
Wed Jun 22 2011, 01:23AM
Forty wrote ...
Well a split phase motor does use a start capacitor. The capacitor gives the start coil a pulse whose magnetic field is a different phase angle than the main winding, which makes the rotor rotate. An AC induction motor with no start winding can be energized, but without the initial kick the start winding provides, the rotor may not rotate and just sit there and vibrate. Especially if there is a load.
You could use something like Link2 to bypass a limiting inductor or resistor. You could replace the opto isolator with a relay (be sure to use a freewheeling diode across the coil of the relay).
