  • Guests: 52
Best Soldering Iron for ~$20
Chip Fixes
Wed Jun 15 2011, 02:02AM Print
I need a quality soldering iron with a variable heat setting. Somewhere around $20 but I will pay more if it's a good one
Any suggestions?
currentkills91
Wed Jun 15 2011, 02:24AM
This one here seems like a decent soldering iron, 25-60 watt adjustable.
Wed Jun 15 2011, 02:34AM
Link2 This is what i use. It is a simple iron, but it differs from radio shack soldering irons and some others i have tried in that it just won't die! It has been through hell, and it looks like hell, but it works fine. I even use lighters to heat it up faster when i don't feel like waiting. I know it is abusive, but i got it for 16 dollars so sue me tongue Then, get (or make) a 7 dollar light dimmer, and voila!
I have just never liked the soldering irons with the variable heat, mostly because the ones i have used had large tips or were just too large. Mine is small and has a neon indicator light which has saved me from many a debacle.
Chip Fixes
Wed Jun 15 2011, 03:35AM
oh wait... a light dimmer would work wouldn't it :D I didn't think of that, I've got a good iron right now quality wise, with two heat settings (high and low) but it is either too hot or not hot enough haha, if I just wire in a light dimmer than it should still work?
Wed Jun 15 2011, 03:48AM
Yes, it is a resistive load like a light bulb. However, a light dimmer is obviously way over rated and therefor big tongue.
Chip Fixes
Wed Jun 15 2011, 03:59AM
well I've got an extra one lying around, so as long as it works :D
Now to find a schem for wattage and temperature readout...
Adam Munich
Wed Jun 15 2011, 04:34AM
Get the elenco SR1N. I've had one for 2 years and still haven't needed to replace the tip!
Chip Fixes
Wed Jun 15 2011, 04:42AM
wow, excellent price!
magnet18
Wed Jun 15 2011, 06:14AM
Camp Badger wrote ...
Same here, 30 watts will fry anything if I'm not quick, 15 will never get anywhere.
At least I can solder fast now (~.5s for a joint)
