  • Guests: 73
Another charger problem
currentkills91
Tue Jun 14 2011, 06:32AM Print
Okay, so I rebuilt my ZVS charger, and it worked perfectly. I was getting 530 volts from the transformer, and none of parts got warm. After testing I decided to add on the regulator circuitry, and to my surprise...it didn't work -.- I flipped the switch and...80 volts from the secondary. I disconnected the regulator and it worked fine again, so I looked over my my layout and didn't see anything wrong. I hooked it back up and the same thing happened. I once again disconnected it, but this time, it doesn't work anymore. I touched my positive lead to my battery and it made a big spark and everything got really hot (mosfets, inductor, wires, even the gate resistors got warm) I've looked over it like 100 times and cannot figure out what's wrong. Can anybody help me figure out whats wrong??
radhoo
Tue Jun 14 2011, 06:52AM
Here's a ZVS using a regulator: Link2
Is this the way you've put things together?
currentkills91
Tue Jun 14 2011, 08:10AM
No, it appears I left a bit of information out. This is a ZVS capacitor charger. This one here
