  • Guests: 66
LTX (57)
01/29 IAmSpock (18)
01/30 Ian (37)
01/30 Lucas (40)
1W ~405nm Laser?
Juniortore1
Sun Aug 07 2011, 12:09AM
Juniortore1 Registered Member #4014 Joined: Wed Jul 20 2011, 05:31PM
its possible to see a 100mW 405nm beam from a simple PHR-803T, its just not that bright... at all. So, 405nm beams can be seen well at 400mW+. The beam and dot would clearly be violet if it is a 405nm. If its a 445nm laser, the beam would be very bright and VERY solid if you shine it in the sky in the dark (make sure there are no planes) and even if cold where the wavelength can go down to about 430nm or so it is still more visibly blue than violet.
Another thing, if it is a 445nm, the beam would be a rectangle where one side is way wider than the other due to being a multimode diode
I have a 1W 445nm laser myself. Here is a video of the beam in the night sky Link2
and here is a video of the 445nm beam close up Link2
@GBD, you still need to manually set your white balance on your camera for that 445 so it looks blue instead of violet =P
Sun Aug 07 2011, 08:51AM
Klugesmith wrote ...
You can determine the wavelength by measuring the diffraction pattern with an inexpensive (and may be unusually coarse) grating between laser and target surface. If the grating pitch isn't exactly known, you can use a laser with known wavelength as a reference.
A fine wire screen (such as used in fuel filters) can serve as a grating and not, I expect, be burned up by the 1W laser. I can send you a bit of suitable screening.
With other grating materials, you may need to turn down the power or use some optics to spread the beam without overly expanding the spot on target surface.
A source of free gratings for demonstrations is the linear encoder ribbon found in many discarded inkjet printers.
In USA they are typically 150 lines per inch, but you can trust it's a round number and can directly measure it with some care. For example, juxtapose it with a reference scale & make enlarged photograph or photocopy on which you can count the lines.
Another source, of course, is CD's or other optical disks. You can look up the standard pitch, and/or use a wavelength reference laser.
Yeah, they are neat aren't they!!
I've made diffraction gratings by putting two pieces at right angles then UV glue.
The sensors out of these are also worth having, many old HP's use an LM35DZ behind the print head on a pcb.
The position sensors can also be hacked if you are into robotics.
