  • Guests: 68
Can anybody solder QNF packages?
currentkills91
Mon Jun 13 2011, 05:52AM Print
I need somebody that I can have solder a bunch of surface mount parts, including a QFN package for me. I do not have the equipment, or the money to buy the equipment to do it myself. I normally never use surface mount parts, but I need to use 'em for some of the protection circuitry for a project. I will pay for shipping the parts to you and for soldering them for me.
Electroholic
Mon Jun 13 2011, 05:56AM
What's the pitch and pin count? QFN can be soldered by hand using a fine tip soldering iron and a specially designed foot print.
Carbon_Rod
Mon Jun 13 2011, 06:16AM
Option 1 tinning:
Option 2 stencil:
Option 3 adapter board:
Cheers,
currentkills91
Mon Jun 13 2011, 06:40AM
Okay, maybe I should of been more clear. I have NO tools for surface mount, I don't even own a hot air gun. I'm mainly concerned with the QNF package though. All my other parts are just things like resistors, diodes, and some caps.
Turkey9
Mon Jun 13 2011, 07:36AM
Where are you? Depending on how much, I may be able to help you.
Mon Jun 13 2011, 08:38AM
Same here.. I can certainly help, as I have magnifiers etc and micro solder.
Just ordered a bunch of 0.5mm solder balls for an experiment in rapid prototyping smile
-A
#include "RoHS-sucks.h"
Daedronus
Mon Jun 13 2011, 11:43AM
You don't really need any special equipment to solder normal SMD parts...
Th
This is a 0.5mm pitch (IIRC) no special tools needed whatsoever, just a steady hand
Bjørn
Mon Jun 13 2011, 12:42PM
QFN does not have pins and in some cases the pads are completely on the underside of the chip.
Daedronus
Mon Jun 13 2011, 01:14PM
oh..hehe, my mistake, I was thinking about qfp frown
ConKbot of Doom
Mon Jun 13 2011, 04:17PM
Bjørn wrote ...
Yeah, no joy at all with those. If you dont have a footprint which allows you to touch the pad with iron and heat that up, then youre really out of luck without a hot air gun/pencil, if the pads are oversized, then you can at least put the first one down with a fine point iron if youre lucky. No real way to rework it and get it off though.
If not then its paste + hot air, or drag soldering tip to equalize the solder on the pads + flux + hot air.
And if its a lovely little RF package, that means your board has huge ground planes, so then its hotplate to pre-heat + hot air
