  • Guests: 62
classic 4046 PLL tesla coil tips
Shrad
Sun Jun 12 2011, 11:21PM Print
hi all
I finally tied together my first SSTC with a classic PLL driver
it has given its first light and I'm happy, but I'm asking your advice here
30VDC, single IGBT (27n120), everything is running fine but there is a bit of heat in the IGBT
what can I do before feeding it 170VDC 2A from my voltage quadrupler ?
I tested it and it popped after perhaps 2 seconds (but I had streamers!)
what do I need to keep it safe?
the IGBT switches the primary (20 turns 1mm enameled wire) to ground and I tried with an external diode
Daniel Kramnik
Mon Jun 13 2011, 02:52AM
Daniel Kramnik Registered Member #3885 Joined: Sun May 15 2011, 12:47AM
First, I would absolutely recommend upgrading to a half bridge of IGBTs - I have seen a few single transistor coils achieve respectable performance, but given that even the simplest half bridge essentially guarantees good results (take Steve's SSTC-5, for example), it seems like a rather obvious choice to me.
Second, how large is the IGBT heatsink? If you want to avoid overheating, the simplest answer is usually involves a larger piece of aluminum.
Third, are you using an interrupter? If not, then you need one. Running your coil in CW will almost certainly lead to fast IGBT failure. On the other hand, if you are using one, then try testing your coil with the pulse rate/pulse width set lower to decrease the stress on the transistor.
Fourth, you need to upgrade your primary with significantly thicker wire, especially if you want to run it at full power.
Fifth, are you sure that your gate driver is giving your IGBT a clean square wave at the proper gate voltage? Excessive ringing can destroy the IGBT's gate, or, if the voltage of the gate drive signal is too low, then the IGBT will not switch on all the way and this can also lead to failure. Try testing the signal on the IGBT's gate with an oscilloscope to make sure this isn't the case.
Finally, try "soft starting" the circuit with a variac - I blew several MOSFETs in my first SSTC by applying full power to it without a variac. Later, you can add a transistor circuit that will soft start without a variac once you are satisfied with the performance. Steve Ward's SSTC-1 uses this type of circuit.
Good luck!
Dr. ISOTOP
Mon Jun 13 2011, 05:02AM
What frequency are you running at? Slow IGBTs (e.g. the Fairchild B3D series) don't like to run over 100 khz, fast ones (e.g. the A4D series) don't like to be pushed over 200.
Shrad
Mon Jun 13 2011, 09:05AM
the frequency is 500Khz-ish, and that IGBT is in the 20ns on-time, 120ns off-time range
I'll try putting an IRF450 there and give it a try before trying to investigate further
switching waveform is nice, there's not much ringing and the driver pair is just warm to the touch after 10 minutes
heatsink is a nice one (athlon xp) and blown by a small fan
I'll get some pics of the IGBT waveforms at 30VDC in and decide what to do, and will use an interrupter btw
thanks guys! I'll post pictures as soon as I have nice streamers
Shrad
Mon Jun 13 2011, 01:11PM
hmm lets enumerate my few problems
I switched to an IRF840 half bridge with PP caps of 1.5µ and fast diodes
I also rewound my GDT to feed the two mosfets but I have much ringing at my GDT output and no voltage (perhaps 2 volts)
Previous winding was excellent and waveform was perfect with the IGBT
The GDT is 12 turns 1mm² primary, 2x12 turns bifilar 0.8mm² secondary on a grey core, 25mm outer diameter
I have tried paralelling gate drivers with no more results
the GDT is powered through a 10 ohm + 0.47µ
Maybe someone could point me to the good direction here? I'm losing patience because I still have to learn in that domain ^^ and I dont understand where the problem could be
Daniel Kramnik
Mon Jun 13 2011, 01:46PM
Are you using bypass capacitors across all of your ICs? Sometimes, insufficient bypass capacitance can cause the voltage to drop on the MOSFET side of the GDT. Then again, you don't seem to be pushing too much power with your coil, so it might not be a problem.
I think you might want to rewind the GDT again - try using a core that you can be absolutely sure is made of ferrite (also try to make sure that AL >= 4000) and made one trifilar winding instead of a bifilar secondary and separate primary - this will greatly reduce leakage inductance and probably solve your ringing problem and help your voltage problem.
Can you post pictures of your driver and bridge, taking a look at the physical setup may help.
Once again, good luck with your project!
Shrad
Mon Jun 13 2011, 03:06PM
Thanks Daniel,
I'll have a rewinding session ASAP
The coil is for sure ferrite, it was used in a feedback transformer from a big SMPS (grey ferrite toroid)
I'll have a try with another one, blue this time, which already has a trifilar winding
Shrad
Mon Jun 13 2011, 04:02PM
here are the shots
I replaced the core with another one (the one switching my igbt easily) and wound 30 turns instead of 12 turns as the signal was spikey
now the waveform is pristine :
1307980331 3215 FT117581 P1010884
1307980331 3215 FT117581 P1010885
1307980331 3215 FT117581 P1010886
Shrad
Mon Jun 13 2011, 05:14PM
still nothing with the half bridge
when powering it with 30VDC I have no light, even if it is in tune (I have 40Vpp across the coil)
when powering it with more than 100VDC the schottkys keep shorting (they are 400V 16A double schottkys with paralelled diode)
I'll wait and see if I can make a better bridge or try with a single IRF450
I have no clue why it keeps behaving badly, so if anyone has an idea I'll take
(I had breakout with 30VDC and a single IGBT switching the coil to ground)
Dr. ISOTOP
Mon Jun 13 2011, 08:10PM
Are you getting anything out of your bridge?
