Bad sound quality
park
Fri Jun 10 2011, 04:02AM
Registered Member #3940
I followed the circuit this:
I succeeded to make plasma.
But the noise is much bigger than the music sound.
When I stop the music , but the noise continues.....
Like no signal in TV
Can I make the music sound bigger and clear?
Forty
Registered Member #3888
adjust the trim pot until the frequency is inaudible. try turning up the volume on your audio source a bit.
ZakWolf
Registered Member #3114
when I built this and tested it I found the thinner the arc the better the sound quality. good luck :)
P.S. Is your GDT working properly?
park
I think it works. but not good phase inversion is bad. not clear. should i have to turn more or less?
