  • Guests: 58
How to identify an IGBT? (Hitachi)
Inducktion
Thu Jun 09 2011, 09:28PM Print
Nevermind, I figured it out!
1307654888 3637 FT0 P1060325
ConKbot of Doom
Fri Jun 10 2011, 11:45AM
*holds a 9v battery up to the screen and zooms out until the size matches*
Whoa, quite a brick there. Is that a module? or a single IGBT with 3 connections to split the current up?
Inducktion
Fri Jun 10 2011, 12:48PM
It's 3 seperate IGBT's in the same package, all paralleled for some ridiculous ratings...
Apparently it can handle 2500 V at 1200 amps.
haxor5354
Fri Jun 10 2011, 10:09PM
a 3 mega watt IGBT brick eh?
whats the peak current rating?
Inducktion
Fri Jun 10 2011, 11:57PM
haxor5354 wrote ...
6-8 kA at around 10-20 uS
NO IDEA WHAT TO DO WITH IT.
haxor5354
Sat Jun 11 2011, 02:31AM
where did you even get it?
are they used in electric train motor inverters?
you can definately make a induction furnace if you have a mega watt power line running to your house
Dr. ISOTOP
Sat Jun 11 2011, 09:43PM
Ooh, that's a beautiful brick smile
I'd suggest an OLTC, but you only have 1, and OLTCs tend to eat bricks. No point in starting a project hinging around a part you only have 1 of when said part is likely to be driven to destruction; you'll feel rather sad when the project dies because the brick died frown
If you had, say, 7 more you could make a scary DRSSTC (4 for the bridge, 4 to replace it when you break it in the quest for more power wink )
Or you could sell it.
Out of curiosity, what are the switching speeds like?
Inducktion
Sun Jun 12 2011, 01:44AM
The switching speed is around 1-3 uS if i remember right.... sort of slow, but its a big brick.
