  • Guests: 60
Capacitor out of CDs?
Alchemist
Thu Jun 09 2011, 04:29PM Print
Alchemist Registered Member #3326 Joined: Sun Oct 17 2010, 09:49PM
In discussing the construction of a Wimhurst Machine with some people on another forum I was reminded that the foil layer of standard CDs is actually conductive. That got me wondering... Has anyone ever tried to make a Tesla Coil capacitor out of a stack of CDs? If so, how well did it work if at all?
Andyman
Thu Jun 09 2011, 04:46PM
It's a great idea, but the problem is that the foil comes far too close to the edge of the disk and flashover would happen as soon as you apply voltage.
Doubl3 Helix
Fri Jun 10 2011, 01:20AM
Doubl3 Helix Registered Member #1548 Joined: Mon Jun 16 2008, 09:22PM
Put the stack under oil in a vacuum? And wrap in paper or PP?
Tesladownunder
Wed Jun 15 2011, 06:04AM
Actually not such a bizarre idea. It might work for a very low capacitance, very high voltage capacitor.
If you used a stack of CD's with a voltage between them of a few kV, each CD will provide a nice voltage division to reduce corona effects. Think MMC with corona rings like in a huge Marx generator. The end CD's would be metal discs of CD shape to allow a metal contact.
The capacitance would be very low per section but with low inductance and a very high voltage.
Still probably easier to use a string of smaller caps to get 100kV plus though.
