  • Guests: 23
Curtis (48)
grenfox (31)
orb (58)
09/27 mcsnwv (38)
09/27 fatboyslim (33)
09/29 Ultra7 (55)
idea: new induction launcher coil design
Forty
Sun Jun 05 2011, 08:03PM Print
how about taking a copper strip like these, soldering a thick wire to each end (parallel to the width, perpendicular to the length,) give the strip a wrap with electrical tape for insulation, and coil the strip about one of the ends to make a coil with a small circular area while maintaining high current capability?
-edit: reason: i've been wanting to come up with a way of inductively launching pre 1982 U.S. copper pennies
Fraggle
Sun Jun 05 2011, 10:34PM
If you mean what I think you mean then it`ll work great. In fact I believe the first drsstc had a primary like that although I`m sure he`ll tell you himself :o)
Mon Jun 13 2011, 12:10AM
Excellent idea. The pancake-coil design is very good at coupling inductively with flat round objects like pennies or flat aluminum disks. The 7KJ Discovery Channel coilgun was built precisely this way, although they call it a spiral coil.
Cheers, Barry
DYI
Wed Jun 15 2011, 01:29PM
DYI Registered Member #1917 Joined: Fri Jan 09 2009, 02:38AM
Even with coils made of normal magnet wire, this works very well for launching copper coins. Last winter I was hitting about 400m/s with quarters from a 5kJ input pulse (destroyed the coils though...)
Wed Jun 15 2011, 02:46PM
DYI wrote ...
Like!
Forty
Sun Jun 19 2011, 05:24PM
That's a hell of a way to flip a coin.
"call it in the air... you'll have plenty of time to decide"
Myke
Sun Jun 19 2011, 08:09PM
I was thinking about making a high power launcher this way except using some sort of plastic for insulation since I'd trust that more. It would also be able to withstand high voltages so some pretty fast pulses could be put through the coil. At really high energies, I'd have to be careful of the coil squishing itself together though the plastic. I'm not sure that's the only force I'd need to be careful of though since the coil itself would try to expand since current is traveling in the opposite direction on the other side of the coil.
Forty
Sun Jun 19 2011, 08:40PM
yea with the greater surface areas facing each other i'm sure it would have to be reinforced a bit. make the spiral and then force some epoxy putty down into it maybe?
my hope was that this kind of design might not explode every time it is fired, and that it could have a small circular surface area.
Sun Jun 19 2011, 10:45PM
How much copper does the coil require to hold itself together?
I don't know but I can offer one sample point ... The Discovery Channel coilgun remained intact after many firings from a 7 KJ capacitor bank. The coil was built with 2mm thick x 10 mm width copper that was wound in a spiral and annealed so it wouldn't try to unwind itself. Just sayin'.
I'm trying hard to be a Type A personality, but I'm just to lazy and apathetic to do it very well.
