  • Guests: 50
Uses of these giant inductor/ferrite core?
hsieh
Fri Jun 03 2011, 01:24PM Print
hsieh Registered Member #1412 Joined: Thu Mar 27 2008, 04:07PM
Someone gave me these giant ferrite core inductors.Are they useful to amateur hobbyists?they seems to be the leftover of a solid state arc welder research project
Can I make HV transformers with them?
1307107457 1412 FT0 Dsc00222
Ash Small
Fri Jun 03 2011, 01:56PM
You should be able to. If you can unwind them onto a spool or something you should have the coil formers/bobbins and enough wire to re-wind them as HV transformers.
Daedronus
Fri Jun 03 2011, 03:55PM
I would try to make a AC/DC TIG welder, perhaps also rewinding them.
Not really HVoltish but still cheesey
hsieh
Fri Jun 03 2011, 04:06PM
Daedronus wrote ...
This is it's original use.But I may need IGBT modules which I can't afford.
I found them in a trash can of a school lab.They said I can take it.I also found one IGBT module.But what can I build with only one IGBT module?
