  • Guests: 52
Discharging a TV
Ash Small
Sun May 29 2011, 07:07PM Print
My TV packed up this afternoon sad Which means I can strip it for parts cheesey
Trouble is, It doesn't have a 'chassis' as such to discharge the HV to.
Where should I connect the other end of the wire to if I want to discharge the HV from under the suction cup?
(It's a big TV and I don't want to take any risks)
I can provide photo's if required.
Sun May 29 2011, 07:25PM
There should be a conductive coating on the outside of the tube (old duffers would call it "dag", from the coating's original trade name, Aquadag) with a copper braid harness to ground it to the circuit board. Discharge the HV to this.
Killa-X
Sun May 29 2011, 07:26PM
I would see what others have to say befor doing this but, when my 40" CRT tube TV died, it sat out for a day. We ended up jamming a screw driver into the ground, with a wire connected to it, with another screw driver at the end. We then poked under the suction cup and after that I ripped it off. So for my case, the tube was successfully drained. But, some CRT tubes can hold charges for years, others will drain out in a couple hours to a day..
Another option is to simple chuck a rock at the screen and clean up after wards. That discharges the tube real easy :D if you don't mind a mess.
Ash Small
Sun May 29 2011, 07:41PM
Thanks Steve. It went 'pop', so I assume it's safe now.
Forty
Sun May 29 2011, 09:35PM
just poke around with only your right hand until you're pretty sure it's all safe. i think you're more likely to get hurt by the muscle spasm causing your arm to fly into something than by the charge itself
Ash Small
Sun May 29 2011, 09:52PM
It's stripped now, but thanks for the advice anyway Forty.
Forty
Sun May 29 2011, 10:07PM
lol it was kind of bad advice. just wanted to reassure you that you probably wouldn't kill yourself if it wasn't discharge properly. hope you find some cool stuff in the tv. don't forget the degaussing coil
Ash Small
Sun May 29 2011, 10:13PM
I didn't forget the de-gaussing coil smile It's the biggest TV I've stripped in a while.....half a dozen biggish heatsinks, big flyback core, and some other interesting stuff, high wattage resistors, biggish electrolytics, other big capacitors, rectifiers, transformers, chokes, other inductors, not looked for diodes yet. (biggish transistors, but not identified them yet.)
(I've kept everything except the CRT and the plastic case (as usual), including the yoke, which, while it can be tricky to strip, yields lots of usable enamelled wire. I'm hoping the speakers will yield the thin wire for my 'moving coil meter' project.)
I normally don't bother discharging them, as they've usually been switched off for sometime before I strip them, but due to the size of this one, and the fact that it had only been off for a few hours I didn't want to take any risks.
radiotech
Mon May 30 2011, 07:55AM
Be sure to check to see if the degaussing coil is wound with aluminum wire.
Many TVs had specific instructions about discharging the ultar. Wrongly
sparking it to earth could damage components.
And even after discharging it, the charge could build up again, sometimes
much later.
