  • Guests: 35
tesla coil with mot
1 2 3 4  last
aris
Mon May 23 2011, 04:20PM Print
aris Registered Member #2871 Joined: Sat May 22 2010, 06:50PM
Hi.I want to make a tesla coil with mots.First of all i wonder what is better 2 mot with a voltage doubler or quadrupler or 4 mot?With 4 mot is been able to use a doubler to take 16kv?I think to make first of all the rotary spark gap with a asychronous motor so i want some information.Motor type UNIVERSAL is good for a rotary spark gap?
MRacerxdl
Mon May 23 2011, 04:29PM
Its easier to make work a Spark Gap Tesla Coil in AC. In DC there are much problems that you can have. I suggest you to use only mots, with any doubler or retifier. Its easier to make work :D
aris
Mon May 23 2011, 05:09PM
so its better to use 4 mots for 8kv output?
Nah
Mon May 23 2011, 08:05PM
Nah Registered Member #3567 Joined: Mon Jan 03 2011, 10:49PM
Yes, however, it will be mesy to isolate all of them. If you look at working designs, most of them start a 12kv, excluding our Dr. Transistor friend.
Dr. ISOTOP
Tue May 24 2011, 12:35AM
If you want to use MOTs (ugh, MOTs!) I suggest a doubler and DC resonant charging or a 2-pack and a doubler; quad-MOT packs are very difficult to make reliably.
Tue May 24 2011, 03:57AM
I agree, 8kv is just too much for MOTs. I would use one MOT and a voltage multiplier. The hard part is finding a charging choke that can withstand the voltage. A few MOTs would work well tongue
Tue May 24 2011, 05:21AM
It is a well established fact that 4 mots work well in spark gap tesla coil service.
Put under oil, centertapped, the voltage stress from secondary to core is only doubled on the outher mot's, and thay do just fine that way.
I have had great results with a coil of that sorts, with a 120nF capacitor.
Cheers, Finn Hammer
aris
Wed May 25 2011, 09:47AM
how can i make an easy ballast for 10A drawing to test my mot?My main fuse rating at 16A so i want to limit the drawing current to 10A..
Nah
Wed May 25 2011, 07:27PM
I belive one of our members used a arc welding machine as a ballest for his tesla coil.
teravolt
Wed May 25 2011, 07:30PM
you could use reactance like a bunch of caps in series or inductors.
1 2 3 4  last
