  • Guests: 44
Where to Accquire Thick Diamater PVC Pipe for Larger Coils?
Daniel Kramnik
Mon May 23 2011, 04:08AM Print
Daniel Kramnik Registered Member #3885 Joined: Sun May 15 2011, 12:47AM
Does anyone know where PVC pipes thicker than 4.5" diameter (the thickest sold in Home Depot) can be purchased? Is there anything else that can be used instead?
I am currently building a small/medium-sized DRSSTC and I need a primary support that will block primary/secondary arcing.
Dr. ISOTOP
Mon May 23 2011, 04:20AM
A flat primary and strike ring work fine for preventing primary strikes; you don't need to wind the primary around a giant piece of PVC.
doctor electrons
Mon May 23 2011, 10:27PM
You can always check with a plumbing supply house. There are a few local to me but you would
need to find one in your area. I used to buy 12 inch pvc with a 1/2 inch wall to make speaker tubes
out of back in the day. They sold me drop off pieces but you may need to buy a whole piece. Just
get the phone book out wink
Killa-X
Tue May 24 2011, 02:00PM
I think places here are just local places that only exist here. But we have a place called Godwin Plumbing, which is a master plumbing store around here. The largest they had was 6" diameter PVC pipe. Was like $35 for 3ft, not cheap if you ask me! But like said above, try local plumbing supply houses.
Ash Small
Tue May 24 2011, 02:37PM
Might be worth looking around local building sites, etc. One of the workers may find you an offcut for the price of a drink!
Tue May 24 2011, 08:38PM
If you're not careful, a plastic tube can make flashovers worse. Inserting a thick piece of plastic between primary and secondary actually intensifies the electric field in the remaining air gap. So try to use thinnish plastic and leave a substantial clearance to the secondary.
I've used:
Acrylic tube bought new (pretty expensive!)
Offcuts of HDPE water main (either bought or scavenged from building sites as suggested above)
Other ideas:
PVC air duct (used for lab fume hoods etc)
Plastic sewer or drain pipe (the really big sizes are more likely to be available at a builder's merchant or farm supplies store, etc)
Plastic trash can or laundry basket (try a mega furniture store like Ikea)
ConKbot of Doom
Wed May 25 2011, 12:27AM
Would "sonotube" cardboard concrete forms work if you were to lacquer/urethane/resin coat them to prevent them from absorbing moisture from the air?
Wed May 25 2011, 08:19AM
Probably, many people on the old TCML used Sonotubes as secondary formers and didn't report any problems.
