  • Guests: 30
01/13 si2030 (62)
MOT primary question o.O
currentkills91
Thu May 19 2011, 10:06PM Print
Hey everyone,
Okay so i took apart an MOT to get at the primary to make some new test coils for my coilgun project. When i got the primary out i noticed something...it was light, like really light. I scrapped off the enamel coating and i found a silverish metal underneath. Did they start using aluminum for MOT primaries???
Chris Russell
Thu May 19 2011, 10:38PM
Chris Russell ... not Russel!
It's not uncommon. MOTs aren't terribly efficient in the first place, so manufacturers are willing to add a little more loss to save money in copper.
currentkills91
Thu May 19 2011, 10:52PM
Yeah I kinda seen that coming, do you know if using this wire to make test coils would be a good idea? I really dont wanna dish out the money on wire just to "waste" it...
Forty
Fri May 20 2011, 12:44AM
Aluminum wire would essentially double the resistance of your coil (well, Al is about 62% more resistive than Cu so not quite double.) I'm sure you can find another MOT before you are forced into buying the magnet wire. Be careful with the epoxy flakes on the MOT wire, worst slivers ever, use leather gloves.
Turkey9
Fri May 20 2011, 01:07AM
I ended up using the wire from the first MOT I took apart to try and cast aluminum parts in my wood burning stove. Whenever I find a MOT with copper wire I keep it whole. Ones with aluminum I tear apart.
