  • Guests: 72
Argh! Mouse!
Fraggle
Mon May 16 2011, 03:44PM Print
Fraggle Registered Member #1526 Joined: Mon Jun 09 2008, 12:56AM
Urgh I just saw a mouse in my kitchen, now I have to throw away my food, strip clean everything, put poison down and you NEVER get rid of the little buggers. This is the worst thing to happen this year :(
Nicko
Mon May 16 2011, 04:53PM
Fraggle wrote ...
Get TWO cats. You need two because:
One cat will probably kill the mouse, but if its a "mouser", then it'll catch other mice, bring them in, and maybe they'll escape before being killed. Or maybe the other cat will do this. Or maybe not.
This is why you need the second cat. It catches the left-over mice from the first cat and, if you're lucky, vice versa
If both your cats are or become indolent, incompetent, overfed or infirm, you may need a third cat.
We have four.
HTH
Bored Chemist
Mon May 16 2011, 06:23PM
They say you are never more than 10 feet away from a rat (which must be worrying if you are in a space suit outside the shuttle.) Have you been dropping dead from plague any more than you were before?
in all likelihood, you have been sharing your abode with the mice for ages, and have only just noticed.
Why panic now?
Mon May 16 2011, 07:47PM
With all the ingenuity, knowledge, experience and imagination of 4HVers
why not
Build a better mouse trap
Apparently there only just over 4,400 U.S. patents related to mousetraps.
Nah
Mon May 16 2011, 09:43PM
Nah Registered Member #3567 Joined: Mon Jan 03 2011, 10:49PM
A tesla coil buit into one. This would also solve the food crisis.
Ash Small
Mon May 16 2011, 11:46PM
I was thinking this. some aluminium foil connected to the ground.....and a HV supply connected above.......fried mouse.....(some cheese or peanut butter as bait!)....
Adam Munich
Tue May 17 2011, 01:04AM
^^ sounds smelly.
I support the cat idea, and make sure you put the rodent's head on a stake to set an example for the other mice.
Fraggle
Tue May 17 2011, 02:11AM
I`d love to have a cat but it seems unfair as I live in a flat. I`ll have to go for a thorough clean, flush any holes with turps and be very careful not to drop any crumbs from now on, the kitchen is pretty clean though, I can`t really understand what attracted it in there.
Chip Fixes
Tue May 17 2011, 02:25AM
Fraggle wrote ...
...neighbors...
magnet18
Tue May 17 2011, 03:40AM
Yea, if you live in an apartment complex you probably cant get rid of one on your own, you need to alert neighbors (horizontal and vertical) and get group effort going with mouse traps. Get enough down in all your corners and you should be able to mount a decent defense.
and be glad it;s not a bug infestation... when the flour is moving, you know you need to strip EVERYTHING!
it sucks.
